MySQL DDL Column Edit is Disabled. Why?
The discussion centers around an issue with MySQL Workbench where the columns tab for editing tables is disabled. Users suggest that this might be due to the absence of a primary key (PK) in the table, as similar behavior has been noted in phpMyAdmin when a PK is not defined. One user confirms that MySQL Workbench allows adding a PK, while other tools like phpMyAdmin and HeidiSQL do not restrict editing data in the same way. A solution is proposed to create a primary key using DDL (Data Definition Language) commands, with a specific example provided for executing the necessary SQL code to add a primary key in MySQL Workbench.
WWGD
Hi All,
I am using MySQL in order to design an ERD (Entity Relation Diagram) , and I can make use of
indexes, triggers, etc. but for some reason, the columns tab , which allows me to add data or just edit the
tables is disabled. I have searched online without success. Any ideas on how to enable it ?
Thanks.
Computer science news on Phys.org
WWGD said:
Hi All,
Thanks.
What client are you using?
Likes WWGD
Do you have an pkey defined for the table?
I've noticed similar behavior in phpMyAdmin when a pKey hasn't been specified.
Likes WWGD
Sorry, it is MySQL workbench. @cpscdave : I cannot even get to the point of choosing a PK for the table
Good catch.
I tried it with a table with no PK. MySQL Workbench doesn't let me edit table data. phMyAdmin and HeidiSQL do let me edit table data.
Samy_A said:
Good catch.
Maybe there is a setting in phpMyAdmin that disables this. I don't have any other admin tools installed currently so can't try them out :)
Thanks for your advice, cpscdave, but I cannot even get to choose a PK for the table.
My MySQL Workbench is friendlier, and let's me add the PK.
Can you execute the DDL code to create the PK?
Thanks, Samy_A, never done it before, could you please suggest a ref for how to do it? I know how to use DDL in general to create and populate (insert values into) tables, but I have never done it in MySQL workbench.
WWGD said:
Thanks, Samy_A, never done it before, could you please suggest a ref for how to do it? I know how to use DDL in general to create and populate (insert values into) table, but I have never done it in MySQL workbench.
Enter the code in a SQL panel:
SQL:
ALTER TABLE `test`.`nokey`
CHANGE COLUMN `Column 1` `Column 1` INT(11) NOT NULL
, ADD PRIMARY KEY (`Column 1`) ;
Click on the button with the lightning to execute the statement.
Likes WWGD
