Natural force down incline plane
12 replies · 4K views · last reply
PhizKid
Free-body diagram of a block on a 30 degree incline, with arrows for the weight straight down, the normal force perpendicular to the slope, and a force arrow along the incline; the block is labelled 10 kg.
Find the force and acceleration of the block down the inclined plane
F = ma
We have two unknowns in F = ma
I know there is the gravitational force going straight down, and there is the normal force that is perpendicular to the incline.
What I don't know if is if the force of gravity acting on the block and the normal force are active/reactive for pairs (do they cancel each other out like an object would at rest?) because I'm told every object has at the least two forces acting on it (the force pairs according to Newton's 3rd law).
So I know the force pulling down on the object is gravity, but what other forces are there that I can calculate the force of the object sliding down the incline?
So what are the active/reactive force pairs that cancel each other out on an inclined plane?
The active/reactive force pairs you talk about, as they are described in Newton's 3rd law, don't cancel each other! Why? Because the two forces making up that pair act on two distinct objects.
Their are two pair of active/reactive forces in this problem.
The Earth attracts the block via gravity / the block attracts the Earth via gravity.
The block exerts a force perpendicular to the inclined plane / the block exerts a force perpendicular to the inclined plane .​
The two forces you show in your figure cannot cancel because they don't act along the same line.
So how can we use these 4 forces to solve for the original problem? I don't understand how they interact to form the force going down the inclined plane.
Only two of those forces act on the block.
One of the others acts on the earth, the fourth acts on the incline plane. These two do not affect the block.
To solve the problem, first set up a coordinate system.
I suggest one axis should be parallel to the inclined plane, the other axis perpendicular to the inclined plane.
So then it's the normal force of the surface pushing against the block, and the force of gravity pulling down on the block?
Free-body diagram of a block on an inclined plane, with red tilted x and y coordinate axes drawn along and perpendicular to the slope. Labeled forces: normal force F_N pointing perpendicular to the surface and weight F_g pointing straight down, with angle θ marked at the incline.
Why do you suggest setting up a coordinate system in this way? Why not just straight up and down (with the y-axis parallel to the side of the inclined plane)?
Free-body diagram of a block on an inclined plane with red tilted x and y axes; normal force FN points perpendicular to the incline and weight Fg points straight down, with angle theta marked at the base.
Work the problem both ways to see.
With this set-up, what is ay, y component of acceleration ?
Well, the acceleration is in the direction of the negative x-axis, so I guess the positive y-axis would be the acceleration's a_y direction, but acceleration doesn't have a y-direction in this case since it's only moving along the x-axis with this set up. So the y-component of the acceleration here is just 0.
Yes, ay is zero, which is a good reason to set-up a coordinate system in this way. If you would need to know the normal force, N, for any reason, this coordinate system would be a big help.
So, what is the y-component of the net force?
What is the x-component of the net force?
I cannot seem to find the angle...the 30 degrees is situated on the coordinate plane awkwardly and I do not know how to move it appropriately/legally to get it into standard form.
I assume a horizontal base for the wedge which forms the inclined plane.
The force of gravity is vertical, so you have a right triangle with one acute angle of 30°.
What's the other angle?
I don't understand "horizontal base for the wedge which forms the inclined plane."
How is the force of gravity vertical? It is a vector in the 3rd quadrant pointing somewhere southwest of the origin.
