Nature Physics on quantum foundations
460 replies · 35K views
CoolMint said:
I think it is quite safe to assume that this underlying reality does exist between measurements.
But it's meaningless, or at least unscientific, to say anything more specific about this reality. Is it what you are saying?
vanhees71 said:
If there's nothing, nothing will be observed, i.e., observing something is scientific evidence that there is this something. I think this is a pretty empty philosophical discussion once more. What should this be good for?
It's good for proving that you are a quantum computer, as defined in post #191. :oldbiggrin:
Demystifier said:
Beables, by definition, exist prior to both observation and interaction with a measurement device. But you seem to imply that any observable is also a beable, which is wrong.
Might it be more accurate to say that it is a beable which interacts with the measurement device to give an observable (without implying all beables will give rise to observables)?
Demystifier said:
Because it's not scientific, there is no experiment showing that things exist when we don't observe them.
Ontology is by definition things that exist even when we don't observe them, and you always say that ontology is not scientific.
There are two different "exist" that people use, and often they are not carefull in their language, which causes confusion. (Why? I don't know. Sometimes I think they do it on purpose.) One is the actual ontological sense of exist. The other is the existence of values of observables. Fro example QM says that it is not always meaningful to say that an electron has spin "up" in a given direction unless measured. But QM doesn't say that the electron doesn't exist unless measured.
No. First, it's not clear what does "it" refer to. Second, beable is not an operator, so it's not clear how a non-operator may "give" an operator (observable).
What "underlying reality" doesn’t “exist” between measurements? At least, one should denote the character of the “underlying reality” one has in mind.
Here you mean "exist" in the ontological sense, right? Can this ontological existence of electron be described mathematically?
We have one notable detail about the underlying reality. Mathematics plays a substantial role in it. Hopes are we can get more out of it in this route.
It gets more and more abstract though. Both string theory and LQG say that space and time and the dimensions are emergent, so we are on scientific terms when discussing emergence.
So if we say something about reality in a mathematical form, then we have better chances to produce concrete results, would you agree? Well, Bohmian formulation of QM expresses possible reality in a mathematical form, just sayin'.
I'm thinking the observable [in a Stern-Gerlach experiment] is the flash on the photo plate
Would a beable be whatever "it" is, that interacts with the photo plate, prior to that interaction.
To try and clarify further: if we consider a Stern-Gerlach set-up without the photo plates, so there is no flash on the photo plate, there is no observation but there would still be beables.
Am I in the right ball park?
The point I was making was that one should be clear when one talks about ontology/exist. Some people, this includes you, are not clear at all to the point that it seems intentional.
We can certainly describe this underlying reality even better. The multidimensional Hilbert space with its degrees of freedom and other similar mathematical tools are probing deeper than any other physical(material) tool. Maybe we can build a model of what underlies everything. Of all the observations. For now, it seems the mathematical model of Hilbert space is what exists between measurements. As an accurate model at least(not as a physical object).
Quite intriguing topic, btw.
The observable in the SG experiment is the spin of the particle, not the flash on the photo plate. More generally, an observable of a system is constructed from a spectral decomposition of the state space of the measured system, not the state space of the system performing the measurement. The flash of the photo plate would be better described as a pointer.
No, that's not "observable". The thing you have in mind would better be called perceptible, a notion I introduced in the paper linked in my signature.
Thanks for that clarification.
Thanks. I read your paper a long while ago, I'll give it another read
Demystifier said:
For example, I like to think that the Moon has a round shape even when it isn't observed, so for me the shape of the Moon is a beable.
...but never square
Demystifier said:
You are trying to define beable by using only the language of standard QM, which is impossible.
Then it's useless. If I want to provide a language/interpretation for standard QM, it must be within standard QM.
Yes, but the thesis behind the notion of beable is that the standard QM is conceptually incomplete, so new concepts are needed to develop non-standard QM.
One of the reasons it's conceptually incomplete is the fact that it cannot explain emergence of macroscopic laws from the microscopic ones, because standard QM already contains a macroscopic law as a part of its unexplained fundamental axioms. By that I mean the Born rule, which in standard QM is valid only in the measurement context, which is a macroscopic notion.
Demystifier said:
In the standard formulation of QM that's true. But it's legitimate to consider a non-standard formulation, if it can lead to some advantages over the standard one.
Again, it cannot be related to standard formulation of quantum theory, but it is related to a non-standard formulation.
Objective collapse models, for example.
I said that reality may or may not exist between measurements. A logical deduction would require that any under-lying reality(if it exists) exists even between measurements.
The character of the underlying reality the substrate of all being given what we know about this reality could be many things, incl my own brain.
Who says that you experience reality as it is? I can only speak about the reality from within the experience. It could be that one day an integrated discipline between fundamental physics and neurology will give us a picture of nature without the bias of the(useful) mental constructs.
You will likely say that I am my brain and this is so. Until you pass out. Then you are not in the reality, but your brain is. This separation is hard to fathom and takes time.
*Useful for survival and not much else
PS. I am studying neuroscience with the hope to get some additional details about these questions
Please note that this forum is about quantum interpretations, not neuroscience.
I think he suggested that neuroscience can be relevant to quantum interpretations. It's not even a weird position, given that many interpretations claim that subjective observations play a fundamental role in quantum interpretations.
That's what I always guessed, i.e., that Bell was thinking that Einstein was right and that QT is incomplete. Also Clauser, as I read in one of the many newspaper features about the new Nobel laureate, was hoping to disprove QT. The more convincing are all these experiments: I.e., it disproved the expectation of some of the protagonists (both theoretical and experimental). So, indeed, the buzz-word "beable", which still doesn't seem to be well-defined anyway, is just a buzz-word, and nothing else. For me the trick with Bell's papers on the foundations of quantum theory is to ignore most of the words between the formulae and fill in the words by yourself. Together with all the experiments deciding in favor for QT and against "local realism" I get more and more convinced about the formalism with the minimal interpretation: There are neither hidden variables nor determinism concerning the values of observables. All there is to specify about a concrete physical system in the lab is the quantum state (represented by the statistical operator with the meaning to describe the result of a specific preparation procedure), and the meaning are probabilities for the outcome of specifically given measurement procedures, i.e., quantitative observations on the system with a given measurement device.
Together with locality (i.e., microcausality) of relativistic QFT this implies that indeed in entangled states the observables of specific parts of a system, that can be observed at arbitrarily far-distant places with space-like separated measurement events and even space-like separted choices of measurement protocols, do not take predetermined values, i.e., the outcome of their meausurement is probabilistic, and the statistical properties are given by the quantum state the measured system has been prepared in, and this implies that despite the indeteriminism of the observable there are the very strong correlations between observables, as described by entangled quantum states. These correlations are there due to the preparation in the entangled state, and (within local relativistic QFTs) no faster-than-light spooky action at a distance due to the choice of a measurement setup and observations on the values of the measured observables is needed to explain these correlations.
It can. Standard quantum-many body theory explains the "emergence of a classical world" via "coarse graining", defining the "relevant macroscopic observables".
I didn't say that macroscopic laws cannot be explained from standard quantum laws. They can. I said that macroscopic laws cannot be explained from purely miscroscopic laws. The standard quantum laws are not purely miscroscopic, since the standard Born rule is not purely microscopic.
See also https://www.physicsforums.com/threads/is-quantum-theory-a-microscopic-theory.974961/
vanhees71 said:
The only theory that's really both microscopic as macroscopic is QT, and Born's rule applies to both microscopic and macroscopic systems.
The Born's rule applies only in the measurement context, which requires a measuring apparatus. How can measuring apparatus be microscopic?
Quantum theory is about the statistics of the outcome of measurements. What else should it be about? I didn't claim that a measuring apparatus is microscopic. Nevertheless QT describes both microscopic objects, which can be measured and macroscopic objects, including measurement apparati. There's no "Heisenberg cut", and the same quantum-physical laws work for measurement devices as for any other (macroscopic) piece of matter.
vanhees71 said:
Together with locality (i.e., microcausality) of relativistic QFT this implies that indeed in entangled states the observables of specific parts of a system, that can be observed at arbitrarily far-distant places with space-like separated measurement events and even space-like separted choices of measurement protocols, do not take predetermined values [...]
I find that a rather peculiar notion of locality. I wouldn't call a theory local if it deals with such strange systems, having parts "at arbitrarily far-distant places", as one system. Yes, "local realism" has been ruled out, but I'd prefer to throw out locality rather than realism. You are still far away from a truly minimal interpretation: QFT is a machinery for calculating correlation functions (of events). I think talk about "entangled particles" just carries too much metaphysical baggage; we should be content to have a theory that let's us calculate the correlations between events. (It is not necessary to call them "state preparation" and "measurement".)
