Necessary to remove an electron from the surface.
  • Thread starter Thread starter omni
    Electron Surface
6 replies · 3K views
omni
it known that photon of Electromagnetic radiation Cause to an electron emission from Metal surface.
the velocity of the electron is 3.6*10^3km/h
i Calculate the Wavelength of the electron with the formula [tex]\lambda[/tex]=h/m*v
it is written that when the frequency radiation are low than 2.5*10^16Hz so there are no any electron emission from the Metal surface.
now i asked to find how much energy are necessary to remove an electron from the surface.
so i need to use the formula 1/2me*v^2=hv-[tex]\Phi[/tex] all i need is to find [tex]\Phi[/tex] ?
thanks.
thanks.
Hello Omni.
You are using the variable "v" in two different ways. The v on the left hand side is the velocity of the ejected electron. The v on the right, likely should be the Greek letter ν (nu), which is the frequency of the photon. ( You might rather use f for frequency)
c = λ ν, where c is the speed of light.
yes that is correct.
"c = λ ν, where c is the speed of light." how this can help me here?
in this formula v is also mean nu (frequency )
but i need to find how much energy are necessary to remove an electron from the surface.
thank you.
You need the electron's Kinetic Energy to be greater than zero : KE > 0.
Use that with:
(1/2)meve2 = hf - Φ.
Find the frequency, f, then find λ .
thank you again.
so tell me if i correct:
1/2*(9.109*10^-31*(3.6*10^3)^2)=(6.626*10^-34*2.5*10^16)-[tex]\Phi[/tex]
till here i correct?
thank you.
omni said:
thank you again.
thank you.
It looks good to me.
hi.
ok so all i have to do now is to find [tex]\Phi[/tex] by doing hf-1/2me*V^2 and we know the value of each of this formulas as i showed before.
so i do like this: (6.626*10^-34*2.5*10^16)-(1/2*(9.109*10^-31*(3.6*10^3)^2))=[tex]\Phi[/tex]
hope you can understand something in this mess :smile:
really thanks for your help.
