High School Need a formula for this scenario....
  • Thread starter Thread starter Intle
    Formula
This discussion focuses on calculating the movement of atoms between two containers with different pressures and volumes, specifically in an adiabatic scenario. The original container has a volume of 1 unit and is connected to a second container with twice the volume, leading to a final distribution where two-thirds of the atoms occupy the new container. Key formulas discussed include the adiabatic process equation T1V1^(γ-1) = T2V2^(γ-1) and the root mean square speed formula, Vrms = √(3RT/M), which relate temperature, volume, and atomic velocity changes during expansion.
  • Understanding of adiabatic processes in thermodynamics
  • Familiarity with the ideal gas law and its applications
  • Knowledge of root mean square speed calculations
  • Basic principles of gas behavior under varying pressure and volume conditions
  • Study the derivation and applications of the adiabatic process formula
  • Learn about the ideal gas law and its implications for gas behavior
  • Explore the concept of root mean square speed in greater detail
  • Investigate real-world applications of adiabatic and isothermal processes in engineering
Students and professionals in physics, engineering, and chemistry who are interested in thermodynamic processes, particularly those involving gas behavior and atomic movement in varying pressure environments.
Intle
So I've been wondering if anyone knows a formula to relate these quantities in this scenario.
Say I have a container that originally has some volume, some amount of atoms at a constant velocity and is at a certain pressure and is airtight and then connect it to another container that has twice the volume and is at a very low pressure. Now some of these atoms will move from the first container to the second container due to the difference in pressure. Is there a formula I could use to calculate how many of these atoms move over to the second container to reach equilibrium?
What about a change in velocity of the atoms?
Is there a formula I can use?
If you consider the two volumes reach equilibrium after some time then you could use volume ratios to determine the atoms in each one and knowing the atoms in the second container before they were connected you could determine how many moved, right?
Likes CWatters
Looks like two thirds of the atoms will end up in the new container.
Thinks like final pressure and temperature depend if the containers are insulated or not. Google adiabatic, isothermal, and possibly isobaric.
Ok, so could you show me how you got this value?
It would be an adiabatic scenario, and yes it is supposed to be insulated. It is an ideal scenario. I'm a bit more interested on how to find a change in velocity of these atoms. Ofcourse I am assuming that there will be a change in velocity, and I could be wrong in this assumption, but I thought that the change in pressure would cause the gas to move into the area of very low pressure. I would like to add that this area is supposed to be very close to a vacuum.
γ
The volume increases from 1 unit to 3 units. That means the original container represents 1/3rd of the final volume and the new container 2/3rds. If the temperature and pressure ends up the same in both then the atoms will end up distributed uniformly. So there will be 1/3rd in the original container and 2/3rds in the new container.
If the container is insulated the gas will cool as it expands. I believe you need to know the adiabatic index γ of the gas to work out the final temperature and pressure. No matter.. If both containers end up at the same temperature and pressure then I would still expect the distribution of atoms to be uniform.
I believe you can calculate that...
The temperature will change as the gas expands and Temperature is related to the average (rms) velocity of the atoms...
If you had gas at temperature T1 in an insulated syringe of volume V1 and simply allowed the gas to expand to volume V2 by pulling or releasing the syringe the gas would cool down to T2..
Formulae for adiabatic process can be found here..
https://en.wikipedia.org/wiki/Adiabatic_process
I'm a bit rusty but I think..
T1V1γ-1 = T2V2γ-1
So if you know T1, V1, V2 and γ you can work out the final temperature T2
The before and after rms velocity of the atoms can be calculated from T1 and T2 as per...
https://en.wikipedia.org/wiki/Root-mean-square_speed
Just to continue..
From https://en.wikipedia.org/wiki/Root-mean-square_speed
Vrms1 = (3RT1/Mm)
So the ratio of the rms velocities would be..
Vrms2/Vrms1 = √T2/√T1 = √(T2/T1) ........(1)
From earlier
T1V1γ-1 = T2V2γ-1
so T2/T1 = V1γ-1/V2γ-1 ...(2)
substitute into (1) gives
Vrms2/Vrms1 = √(V1γ-1/V2γ-1)
So quite a simple relationship between the rms velocity and change in volume.
As I said I might be rusty!
Edited to correct a few typos.
CWatters said:
Just to continue..
Vrms1 = (3RT1/Mm)
From earlier
T1V1γ-1 = T2V2γ-1
Thanks, precisely what I was looking for.
  • · Replies 49 ·
  • · Replies 16 ·
