How Do You Calculate Work Between Protons and Solve Capacitor Charge Problems?
The discussion revolves around calculating work related to the interaction of protons and solving problems involving a point charge in a parallel-plate capacitor. The first problem involves determining the work required to bring three protons into proximity, while the second problem focuses on the behavior of a charged mass suspended in an electric field.
  • Mixed
  • Participants explore the concept of work done in assembling charges and question the method of adding charges one at a time. There is also discussion on the forces acting on a charge in a capacitor and the potential need for understanding torque.
Some participants have provided insights into the work calculation for the first problem, while others express uncertainty about the methods suggested and seek alternative approaches. The discussion is ongoing, with attempts to clarify concepts and explore different lines of reasoning.
Participants note that certain concepts, such as torque, may not have been covered in their coursework, which could limit their ability to fully engage with the second problem.
cdf0688
ive looked at both of these for about an hour and can't figure them out
the first one:
How much work is required to bring three protons initially infinitely apart, to a configuration where each proton is 1.5x10^-13 m from the other two? (This is a typical separation for protons in a nucleus.)
second one
A point charge of mass 0.071 kg and charge +6.77x10^-6 C is suspended by a thread between the vertical parallel plates of a parallel-plate capacitor. (a) If the charge deflects to the right of vertical, which of the two plates is at the higher electric potential? (b) If the angle of deflection is 22 degrees, and the separation between the plates is 0.025 m, what is the potential difference between the plates?
I know that the answer to A is the plate on the left, but i don't know how to find part B.
Any help would be appreciated, thanks
For the first one, add the charges one at a time. The first is free, the second must work against the field of the first, etc. For the second problem, add up the torques from gravity and the EM field and find how strong the field must be for there to be no net torque.
Im not quite sure what you mean my add the charges one at a time for the first problem? And on the second one, there must be another way to find the answer, i don't think we have gone over anything dealing with torque in our class yet. Got any more ideas?
Thanks for the help though. I am going to go back to staring at the problem and hoping it magically comes to me.
I'm saying, if you wanted to actually assemble the charges in this arrangement, you'd have to take each one in from very far away (ie, so far away that they have no effect on each other). The first one takes no work to move into place, because there are no charges nearby. For the second, there is the constant force it feels due to the first that you must work against. And similarly for the third, where this case you must work against both the first and the second charges. The total work is the energy "in" the arrangement, because it is the work you would get out of the arrangement if you dissassembled it (ie, let it explode).
For the second problem, if you don't know torques, you'll have to include all the forces on the charge: electrical, gravitational, and the tension ofthe string. These are all in a known direction, and must add (as vectors) to zero. Your unknowns are the magnitude of the electric force and the magnitude of the tension, and you'll get two equations from the x and y components of the vectors to solve for these.
Okay i think i figured out the first one:
I took the equation deltaU = k(q)(q1)/r and plugged in the numbers and did that three times and added them togehter.
And like you said at a great distance they do not affect each other so their original potential is zero
and from that i got that the deltaU would equal 4.608x10^-31, which if i under stand right is equal to -W.
Still trying to figure out the second one
Thanks again for the help
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 26 ·
