Might want to edit your post and delete the unnecessary copies of the template :P
Anyway, when you throw something upwards at a given speed, it means its speed will decrease by g m/s every passing second.
If the window is 12 feet high - what is that in metres - 3.66 metres or so.
So the height relative to where you were throwing it is not 12 metres, but 12-3.66.
But there is a problem with the assignment - the ball at this small initial velocity cannot reach 8.34m height from the window if thrown up vertically. And it pretty much is showing in the numbers, your speed will decrease 9.8m/s every second, your initial speed is only 5 m/s, it means after 1 second it's already falling back down.
I calculated the minimum speed at which you will have to throw the ball and it is ~12,785m/s for it to even reach 8.34 height from the window.
Am I reading the assignment wrong? It is asking for the object's speed at 12 metres height from the ground with a given initial speed isn't it?
