Derivatives Homework: Solving for D_x of (1/x^2 - x) and Limits
  • Thread starter Thread starter Equilibrium
    Derivatives
The discussion focuses on solving the derivative D_x(1/x^2 - x) using the definition of the derivative. Participants clarify the steps involved, emphasizing the importance of rewriting the function f(x+h) and f(x) correctly. The derivative is ultimately calculated as -2/x^3 - 1, demonstrating the application of the power rule and limit definitions. The conversation highlights the necessity of showing detailed steps in the solution process for clarity and accuracy.
  • Understanding of limits, specifically lim_{h -> 0} for derivative calculations.
  • Familiarity with the power rule for differentiation.
  • Ability to manipulate algebraic expressions, including fractions and polynomials.
  • Knowledge of the definition of a derivative and its application in calculus.
  • Study the application of the limit definition of a derivative in various functions.
  • Practice rewriting complex functions for easier differentiation.
  • Explore advanced differentiation techniques, such as implicit differentiation.
  • Learn about higher-order derivatives and their significance in calculus.
Students studying calculus, particularly those focusing on derivatives, as well as educators seeking to enhance their teaching methods in explaining derivative concepts.
Equilibrium
D_x(\frac{1}{x^2}-x)
\lim_{h \to 0} \frac{f(x+h)-f(x)}{h}
\lim_{h \to 0} \frac{\frac{1}{2xh}+\frac{1}{h^2}-h}{h}
I don't see much of a "problem statement". If I were asked to find the derivative of \frac{1}{x^2}- x, I would write it as x^{-2}- x, and then use the power rule: the derivative is -2x^{-3}-1= \frac{-2}{x^3}- 1.
If the problem itself requires that you use the definition of the derivative, say so!
What is \frac{1}{(x+h)^2}- \frac{1}{x^2}?
Show more steps but...
If you have to use the definition of a derivative to solve,
f(x+h) = what? Plug in x+h into the original equation and show us what you get. Then show us what f(x+h)-f(x) looks like.
edit::Sorry HallsofIvy, didn't see your post before I posted :P
hint (x+h)^{2}=x^2+2hx+h^{2}
thank you for all the hint
i was really told to do it the long cut way
where i was stuck was:
\lim_{h \to 0} \frac{\frac{1}{(x+h)^2} - x - h - \frac{1}{x^2} + x}{h}
then i cancel the x...
then
\lim_{h \to 0} \frac{\frac{1}{x^2+2xh+h^2} - h - \frac{1}{x^2}{h}
then i cancel the \frac{1}{x^2}
then this was the part where i got stuck:
Notice that
f(x+h)=\frac{1}{(x+h)^{2}}-(x+h)
and
f(x)=\frac{1}{x^{2}}-x
so
=\lim_{h \to 0} \frac{(\frac{1}{(x+h)^{2}}-(x+h))-(\frac{1}{x^{2}}-x)}{h}
=\lim_{h \to 0} \frac{\frac{1}{x^{2}+2hx+h^{2}}-\frac{1}{x^{2}}-h}{h}
After this point you will need to rewrite both fractions on the numerator as one giant fraction and divide each term by h and then evaluate
(x+y)^{2} = x^{2}+2xy+y^{2} it is NOT x^{2}+y^{2}
\frac{1}{(x+h)^{2}} = \frac{1}{x^{2}+2hx+h^{2}} it is NOT \frac{1}{x^{2}}+\frac{1}{h^{2}} or anything like that.
I got it...
\frac{-2-x^3}{x^3}
i am very thankful for all your help
Correct.
No problem at all, happy to help you. I would rewrite it though.
\frac{x^{2}-1}{x^{2}} = 1-\frac{1}{x^{2}} (Just demonstrating how, you should be able to apply it and simplify)
But that's up to you and I would think that the format you have it in now is okay.
  • · Replies 19 ·
  • · Replies 20 ·
