Need help w/ understanding electric potential
The discussion revolves around understanding electric potential, specifically in the context of an electron moving between two points with different electric potentials (100 V and 200 V). The original poster expresses confusion regarding the relationship between electric potential and energy, seeking clarification on the concepts involved.
  • Participants discuss the relevance of energy concepts in relation to electric potential, with one participant attempting to calculate potential energy but expressing uncertainty. Questions about the implications of the electron's charge and the importance of including units in calculations are also raised.
Some participants have provided guidance on the importance of recognizing the electron's negative charge and the necessity of including units in calculations. The original poster indicates progress in understanding but acknowledges the need for further exploration of the underlying concepts.
The original poster mentions confusion with electric potential in general and seeks resources for better understanding. There is an indication that the discussion may be influenced by the timing of the inquiry, as one participant notes the late hour of the original poster's post.
teetar
An electron moves from a point in space where the potential is 100 V to another point where the potential is 200 V. If it started from rest, what is its speed at the end of the trip?
I'm not sure what's relevant and what's irrelevant at this point.
I thought this had something to do with energy, found potential energy at 100 V to be 100 * 1.6E-19, but that doesn't seem to lead me in the right direction. I'm very confused with electric potential in general at the moment, can anyone suggest any resources that will explain it in such a way that even I can understand it?
Thanks!
You are on the correct track apart from two things.
1. The electron charge is negative, not positive.
2. You should always (always) write out the units. Saying the energy is a number without giving the units is meaningless.
Thanks, I was able to figure it out! Once I recalled electrons were negative (maybe I shouldn't be doing this so late at night) the numbers made significantly more sense. I wrote up my original post a little hastily, but I do typically put in units. I was able to solve it using total energy calculated from its position at rest, and finding what the kinetic energy must have been given potential energy at the 200 V point in space. I was able to do the math, but I still need to spend a lot more time on the concept.
Thanks for your help!
  • · Replies 22 ·
