Need help with a planet....and other questions
  • Thread starter Thread starter KristijanT
  • #31
Czcibor said:
Does your space ships use nuclear fusion?
While I have come up with a (very fictional,though) concept that will allow space-travel between huge distances,to be honest,I haven't thought about how would a spaceship work! Lithium,would,I guess,play a big part in this,but what about beryllium,too?
  • #32
Seems that can be used:
https://en.wikipedia.org/wiki/FLiBe
For me lithium looks like obvious choice in fusion, while beryllium is a merely one of many possibilities.
How would a spaceship work? Either in way that violates a few laws of physics or in a way that would make your readers fall asleep. :D
(yes, that's how it works in SF...)
  • #33
I'd rather choose the first!
Though -- shielding from radiation would also be needed.Boron nitride shows great promise here.
To quote Wikipedia...: "Like BN fibers, boron nitride nanotubes show promise for aerospace applications where integration of boron and in particular the light isotope of boron (10B) into structural materials improves both their strength and their radiation-shielding properties; the improvement is due to strong neutron absorption by 10B."
en.wikipedia.org/wiki/Boron_nitride#Boron_nitride_nanotubes
Also -- what do you think about solvated electrons being an energy source on the planet? Check this out.
www.newscientist.com/article/dn25894-meet-the-electric-life-forms-that-live-on-pure-energy/And,finally.About boosting atmospheric pressure -- I don't know how much would be sufficient enough for,liquid ammonia,to have,for example,a temperature span of 80-100 C(-77 C to 3-23 C).
  • #34
I tried to find a nice phase graph. I failed
Idea:
http://www.peacesoftware.de/einigewerte/nh3_e.html
Try some values and determine that by trial and error.
EDIT: There is something wrong with this calculator or I operate it incorrectly.
EDIT2:
6 atm would be enough, as bonus it would be liquid under room temperature
  • #35
So...according to this,under a pressure of 10 bars(9.86923 atm) ammonia should have a boiling point of 25 C.That should be ample for life,right?
  • #36
Seems like huge margin.
Under such pressure you can also expect liquid CO2.
One more thing. You wanted a big planet:
f the radius of our planet were larger, there could be a point at which an Earth escaping rocket could not be built. Let us assume that building a rocket at 96% propellant (4% rocket), currently the limit for just the Shuttle External Tank, is the practical limit for launch vehicle engineering. Let us also choose hydrogen-oxygen, the most energetic chemical propellant known and currently capable of use in a human rated rocket engine. By plugging these numbers into the rocket equation, we can transform the calculated escape velocity into its equivalent planetary radius. That radius would be about 9680 kilometers (Earth is 6670 km). If our planet was 50% larger in diameter, we would not be able to venture into space, at least using rockets for transport.
That was calculated for Earth composition, sure. Your ice ball would be lighter, I assume, nevertheless...
http://www.nasa.gov/mission_pages/station/expeditions/expedition30/tryanny.html
  • #37
Good thing,bad thing(or...uhm,neutral thing)? :D
Well,if it would be a problem,to be honest,that could very easily change!
Well,I don't imagine the planet as an ice ball...but,nevermind -- so a big(ger than Earth) planet isn't a problem,then?
  • #38
Mountain glaciers of dry ice, that actually melts, flows downstream and evaporates before reaching sea level? Sounds interesting.
One issue. For my purposes I consider as cool building a planet that is weird and all weirdness is perfectly according to laws of physics. That civilization had to be built in different way, not because of any choice but because of environmental determinism. On the other hand when I discovered such stuff too late, it required some rewriting.
Actually big rocky planet can work. And you can be delighted that local civilization haven't sent a space rocket before invention of fusion nuclear engine. Because of dense atmosphere they may had problems to see stars at all, so they may have started creating rough astronomy as late as during their equivalent of industrial revolution.
Fits your story or not specially?
  • #39
Actually -- I imagined the planet as a...darkish(as I said earlier with the plants being dark to collect more light) with dark-green dots being seen across the lands from Space(that's a...well,special detail :D ),with oceans of brown liquid ammonia(it becomes brownish when it dissolves large amounts of alkali metals).
Interesting,and very cool!(pun intended)
It actually fits my story nicely,and it's definitely a good idea.Now...next thing that could be adressed would be the process of getting energy.As I posted above,maybe solvated electrons that are held in the liquid ammonia could play a big part in this?
  • #40
Right... brown ammonia and no ice caps over oceans... (heavier, sinks)
This part would involve high percentage of handwavium and making stuff up. The only thing that I see here as hard fact - low amount of energy, not so densely populated environment. The rest would be creating plausible story, with very remote contact with hard data. Suggestion: leave it for later, just basing on that that you would finally need.
  • #41
Czcibor said:
...leave it for later, just basing on that that you would finally need.
Well,what I would need is a very very basic explanation on how do the aliens get energy,really.Nothing complex or complicated,just something that could be put in some 1-3 sentences.
Other things I'll need to address: The planet's protection from its host star.On Earth,it is the ozone.On this planet?
I'll also need to create 4 other planets(yep,don't read it again,4 other planets),and I think all of them would be with a biochemistry same as Earth,some with different gravity,and of course,different creatures/environments and all other kinds of differences you can imagine.The positive stuff of this is that I won't need to have much details about the planets because the protagonist won't spend much time on them.
Nevertheless,I won't be focusing on the planets at all before I address all of the problems about the alien planet (with your great help,of course!),create a new element(s) too(they'll have much to do with the ancient alien civilization),and think of an event that will make the aliens' planet(the one we're talking about now) inhabitable -- but due to their only-recently developed(but,nonetheless,much more developed than ours because -- they're much more technologically advanced than us when they start developing it)astronomy they have little time to save themselves and end up doing the decisions that lead to the start of my story.Yep,much work to do,indeed.
Also,at this point,even though there will be much more questions(and hopefully,answers) incoming,I still want to thank you for helping.
  • #42
In non-polar liquid... Hmm...
Requires as water... using some local enzyme produces hydrogen peroxide and dumps hydrogen (lost from the system)? To recover energy first decompose peroxide and later oxidize amonia?
[limited science content, water should be very popular substance especially for such frozen planet, energetically makes sense, peroxide would be frozen and treated as local lard equivalent, no idea whether it would really work]
Make the star smaller:
-would give more time for evolution of those slow species
-would make the star less active in UV
Damn it. I would just feed you with planets that I use:
Amanda:
-binary system, 2/3 of its energy comes from red dwarf that it orbits in slightly above a week (tidal lock), 1/3 in from Sun sized star that is being orbited in 5 years
-terribly frozen, over 60% of surface covered with ice, on the dark side temporary appears frozen carbon dioxide
-oceans 80%
-3 atm
-the only area settled is dry, subtropical region near big rivers (yes, on ocean-ice planet you seek hot and dry place :D )
Mahdi:
-dry planet, water cover below 10% (that actually extends habitable zone, as it harder to achieve runaway greenhouse effect)
-no longer tectonic activity
-minimum axial tilt
-no moon, 14h day
-very hot, only poles are inhabitable
-effectively only one pole settled
USO:
-very young planet 2.5 bln years max
-part of oxygen actually came from water hydrolysis from UV
-already at edge of habitable zone (too hot)
-2 moons, very strong tides
-20h day
-young planet - higher content of U225 to U238 - nuclear fuel does not need enrichment
-too high UV for humans, have to hide for day
JW:
-chthonian planet orbiting white dwarf
-tidal lock
-dense, very rich in metals
-10 km of ice frozen on its dark side, equilibrium achieved because the glacier creeps back and melts
-seas of very high salinity that remain liquid in spite of temp below 0
-only rainy area in the centre is habitable
Viking:
-exomoon, one day (orbit) is 11 days
-sea cover, 70%
-one super continent, effectively uninhabitable
-only inhabitable areas are islands (inside the continent temperature jumps are lethal)
-weird season because of combination of axial tilt and elongated orbit of its gas giant
Octopus:
-4 Earth masses
-very dense atmosphere
-roughly uniform climate below, wet
-strong greenhouse effect
-only habitable areas are mountain ranges
Useful? ;)
  • #43
While I have to thank you for posting planets you already created,and some of the information about them does give inspiration for other ideas,I got to say,that,as I have mentioned in my previous post,most of it would,in my opinion,be too unrelevant to the plot to mention! Though,the mention of binary system just reminded me to an article I have read about a planet in a quadruple star system: now that'd be cool to use!
I didn't quite get you there though...
Actually -- in a reducing atmosphere such as this planet's -- water for the creatures living on the it would be exactly as acid to us.So...I don't think that water would/should be a very popular substance in this planet...
Yeah,sure,though I kinda doubt that it will be enough to shield the planet.
  • #44
It is a practical limit, not a fundamental one. That is the point of staged rockets. The payload to rocket mass ratio goes down, but it does not get impossible.Concerning lithium for fusion: even on Earth we have more lithium than we could reasonably use for tritium breeding in the near future. The hard part is the fusion reactor, not the lithium or deuterium supply.
  • #45
So...question incoming:
What do you think about different-shaped eyes?
No,no,I don't mean different-shaped pupils,but eyes.
  • #46
Why look at what nature already provides?
You can extrapolate from there, but the further you detour from what is proven the more likely you will find errors in your proposals.
  • #47
What for?
I don't see special source of difference here (except maybe a bit less light, a slightly bigger eyes advisable)?
You need some weird stuff for cool factor?
  • #48
Czcibor said:
What for?
Larger eyes are interesting. In one of my books the population genetically modified their eyes to be slightly larger to give their faces a more pedomorphic trait. They simply saw it as a more sexually desirable feature and adopted it as the norm.
So, in some instances features can be artificially enhanced, deviating from the evolutionary norm.
  • #49
And can make the whole planet cute/ turn local population into anime characters. ;)
More seriously, making eyes interesting:
-compound eyes - not specially, may give some minor advantages if the creature used to be a prey;
-different wave sensitivity - maybe - if the star is dimmer, then should see near infra red and can sacrifice violet visibility (drawback - don't visible directly from character, only visible from colors of artificial objects)
  • #50
Haha,nope! For that matter,I actually have a weird enough alien -- I just though that,it's a totally different world,so,there is a good chance that most of the creatures will be very different,eh? Though,of course,I could just put same-looking eyes,and just free myself of complications,but just wanted to put this up here before I do so to have a look at some opinions,and,well,maybe to decide otherwise.
  • #51
You can already have weird creatures without such... cool environment. ;) Superorganisms, symbiotic organisms, non-human shape... Right now I don't see extra features...
One idea... you have water ice beneath ammonia, right? What about burrowing creatures that melt their way through ice? (for some local animals)
  • #52
Need to give advance math to childern in an insight playful matter, too! :biggrin:
  • #53
Yeah,certainly a good idea.BUT...to note: I won't really create a big number of species that would live on the planet.In fact,other than the intelligent aliens on the planet,I plan to create a predator,that would be a kind of a...nemesis to the intelligent alien race during the ages when they were...well,not so intelligent(basically,like our Stone Age),some cool-looking unique plants and maybe some few more (unique,again :smile:) animal species (all of which,I won't go through creating much details,just some basic stuff).
Though,also to note,I've already created a physical look of the intelligent alien race,but it is another area that I need help in,which is...
What event,do you think,would leave that (much more than us) intelligent with little to no time to leave their planet in order to save themselves from extinction?
Obviously,it would have to be an event that would be hard to detect in the right time,but I think the...late astronomical development may explain this...?
Damn,kinda feel like nitpicking,but that's the way it is...:biggrin:
  • #54
Big predator would kill a lot, but still would be quite plenty left (land creature - so sea and flying creatures are mostly left unmolested)Though,also to note,I've already created a physical look of the intelligent alien race,but it is another area that I need help in,which is...
Ideas:
1) Maybe an imminent collision:
https://en.wikipedia.org/wiki/Phobos_(moon)#Predicted_destruction
From the planet it would be obvious, for any far observer - not so easy.
2)Small rouge planet on a collision course.
3) Big (more massive than Jupiter) passing by rouge planet that would destabilize the orbit and after a few violent swings put a planet into habitable zone for carbon based life :D
Don't worry. When I started creating my stuff, from dessert planet with habitable pools I moved to an icy, tidal locked planet. And the political system from a bit improved democracy get serious Brave new world totalitarianism features...
  • #55
If you want an extinction event you might consider a relativistic mass (either natural or not).
For example, Deimos, one of the moons of Mars is just 12.6 km in diameter. It's mass is 2 * 10^15 kg.
At 9/10 C the resultant energy would be enough to fragment Earth into tiny pieces.
The calculations go like this. For Earth you must calculate the binding gravitational energy of the planet (about 2 * 10^32 Joules).
Next, calculate the relativistic kinetic energy of your mass:
Ke = y • mc^2, where y = relativistic gamma = 1/ sort(1- (v^2/C^2))
At v = 90% C, m = 2 • 10^15 kg ==> 2.3 • 10^32 Joules
At 9/10 C you won't have much time to react to such a small body.
Obviously, you don't need to smash a planet to bits. Enough energy to create a world-wide firestorm would do that without fragmenting a planet.
Another natural source is a supernova. The resulting gamma radiation would quickly sterilize a planet if it was close enough ( a few light years) and without warning since the radiation would arrive at C. That assumes there was no real notice of the star going supernova, so you have to be blind to the signs.
Do a search for cosmological planet extinction events and get some ideas.
  • #56
2H2O -> H2O2 + H2
I know about hypervolocity stars, but its still a few of degrees of magnitude to slow for what you suggest.
  • #57
https://www.boundless.com/microbiology/textbooks/boundless-microbiology-textbook/microbial-ecology-16/nutrient-cycles-195/the-nitrogen-cycle-984-5464/
Here's information on the Nitrogen cycle, I know you're looking for the Boron cycle to determine a possible respiratory equivalent, but...
Anyways, with respect to your Boron situation, I also agree with letting it "go away", as we don't even know how a lot of our stuff here came to be. Yea, asteroids, or whatever, but if you can't observe due to a dense atmosphere, you can't get anything but the biggest of asteroids through that atmosphere, they would burn up.
How about this, if you really want a reason for dense boron:
Place the planet orbiting a star close to the center of the galaxy, with a galactic black hole in the center. You get a higher probability of bigger stars, which gives you a higher probability of supernovas occurring, which gives you a reasonable probability to find boron near the galactic center. There could be a star with high boron density across the galactic black hole, which upon self destructing, ejected boron in all directions. Then the boron gets flung around the black hole on either side, and populates this region of space with boron.
I think it sounds plausible.
  • #58
[still wondering about what for nitrogen cycle can be used in this case...]
How plausible is boron star? I don't know about boron, but in case of lithium it is being used as a marker to check whether there was any nuclear reaction on a brown dwarf. If there were, than the lithium would be mostly gone.
  • #59
The stellar surface doesn't change so quickly, but the interior does. This paper suggests we can get days to hundreds of years of warning time for stars in relevant distances (hundreds of light years), depending on the quality of neutrino detectors. Nice for science fiction: you can adjust the warning time as you like.
  • #60
Well, I saw something previously in respect to B-N chemistry, so I could see some use for it, but maybe not.
From what I've gathered, fusion is the most plausible way to get Boron, at least in any quantity. A star of the appropriate size, I'm sure, could collapse into a supernova, and also have a reasonable Boron concentration. This could happen several times, if necessary, supernovas all over the place.
I'm not suggesting that all or even most of the star is Boron, just that it's in a sufficient quantity to be able to seed a planet with copious amounts.
  • · Replies 28 ·
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 87 ·
11K
  • · Replies 24 ·
  • · Replies 18 ·
