Need help with homework question. Anyone please thank you
  • Thread starter Thread starter eddiestylin
    Homework Thank you
To solve the heat absorption problem involving a silver spoon and coffee, the specific heat of silver is required, which can be found online if not in textbooks. The formula for calculating heat absorbed is based on the mass, specific heat, and temperature change. For the second question regarding the cooling of spent steam, a similar approach using specific heat values and temperature differences is necessary. It is recommended to consult the physics textbook for relevant formulas and discussions on heat transfer. Understanding these concepts is crucial for solving both problems effectively.
eddiestylin
a 50.0g silver spoon at 20.0*C is placed in a cup of coffee at 90.0*c. how much heat does the spoon absorb from the coffee to reach a temperature of 89.0*C
HOW DO I SOLVE THIS!
and also this question
Spent Steam from an electric generating plant leaves the turbines at 120.0*C and is cooled to 90.0*C liquid water by water from a cooling tower in a heat exchanger. how much heat is removed by the cooling tower water for each kilogram of spent steam?
You need the value of a physical constant known as the specific heat of that metal (silver). If it's not in your textbook, use google.
so how do i solve it i really don't know this at all.
heat absorbed from the coffee = [Solution deleted by moderator.]
While the OP has seen the solution that was posted, I'll just remark that there should be a discussion of this topic in the OP's physics textbook, along with the formula relating heat and temperature change, plus a list of specific heat values for different materials.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
