Need Help With Pressure Downstream of Solenoid.
  • Thread starter Thread starter Staffy
    Pressure Solenoid
The discussion focuses on calculating the downstream pressure of a solenoid in an air cannon setup, specifically for launching a ping pong ball. Key parameters include mass flow rate and gauge pressure from the reservoir. The primary equation used is F = mass_flowrate * gas_velocity to determine the force exerted on the ball. Participants emphasize the importance of considering factors such as leakage and potential choked flow due to significant pressure differentials across the valve.
  • Understanding of fluid dynamics principles
  • Familiarity with solenoid operation and characteristics
  • Knowledge of mass flow rate calculations
  • Basic grasp of pressure differentials and their effects on flow
  • Research methods for calculating downstream pressure in pneumatic systems
  • Explore the concept of choked flow in valves and its implications
  • Learn about the effects of leakage in pressurized systems
  • Investigate advanced fluid dynamics equations for more accurate force calculations
Engineers, hobbyists, and anyone involved in pneumatic system design or optimization, particularly those working with solenoid valves and air cannons.
Staffy
I have an air cannon, which launches a ping pong ball. The setup for this includes the reservoir, solenoid and barrel. I have to find a function for the range of the launcher. I am currently stuck at working out the downstream pressure for the solenoid. At the moment I have the mass flow rate through the solenoid and the gauge pressure for the reservoir. I was wondering if there was a way of using these values to calculate the downstream pressure acting on the ball?
Any help would be greatly appreciated.
I would look at it more from the standpoint of what force does the mass flow impart on the ball, not what the pressure is. To start with a very rough calculation, calculate the force produced by your mass flow if it were to impinge on a flat plate. That will be your maximum possible propulsive force. You know that you'll never get better than that.
Thanks for your help Fred. I used the equation: F = mass_flowrate * gas_velocity to work out the force on the ball. This seems to give reasonable answers.
Nathan
Don't forget to add a small fudge factor in there as well because there will be some leakage past the ball.
Also, don't forget that if you have an appreciable delta P across the valve, chances are the flow will be choked.
  • · Replies 16 ·
27K
