Need ideas on how to plot this large set of data
  • Context: Undergrad
  • Thread starter Thread starter DyslexicHobo
    Data Ideas Plot Set
3 replies · 2K views
DyslexicHobo
I'm working on monitoring and trending the performance of a memory controller. Without getting into the technical details, I'm trying to find a good way to visualize the data I've collected in a way that will be easy for me to update when I receive new data.
There are about 450 individual sub-module controllers that I'm monitoring about once a month. The value that's being reported each month is a value anywhere from 5 to 30,000 (most are <100, and the ones I'm most interested in visually representing are the ones <100). I have about 200 data points for each of these 450 individual sub-modules, and I just can't figure out how to plot this data in a way that's visually appealing while not leaving out important information.
I'm not really that well-versed in data visualization. I know the basics of Excel but that's about it. I know it's silly to plot all 450 components on one line graph, so I'm hoping there's some plotting method that might apply here.
Let me know if any other info/clarification would help!
so you have 450 modules with 200 months worth of data (ie one datapoint per module per month)?
The only thing I can think of is a color chart with x=month and y=module number and each datapoint as a color (blue <100, green >100 to <1000 and say red > 1000 or whatever color scheme you want. Basically you'd have a map of time vs module number horizontal red lines would indicate a module that has consistently had higher values and vertical lines would indicate a group of modules that had higher values for the given month.
Basically if you know what you're wanting to see then design the chart to show it. As an example, maybe you only want to see those modules with high values in the month so just drop the low value ones. Or maybe you want to plot value ranges vs number of modules within the given range.
This is a great idea! I think I'll use this and just omit all modules with consistently low values.
Thanks for the idea.
Great!
I was also thinking if there are any other features of the modules that could be charted such as location vs recorded data values. As an example, temperature modules being mapped to a physical map showing temperature variations from place to place. Another would be if the modules use different versons of software perhaps grouping them that way to compare software versions vs data values...
