Need to find the Ricci scalar curvature of this metric
chinared
Need to find the Ricci scalar curvature of this metric:
ds2 = e2a(z)(dx2 + dy2) + dz2 − e2b(z)dt2I tried to find the solution, but failed to pass the calculation of Riemann curvature tensor:
<The Christoffel connection> Here a'(z) denotes the first derivative of a(z) respect to z.
\Gamma\stackrel{x}{xz}=\Gamma\stackrel{x}{zx}=a'(z)
\Gamma\stackrel{y}{yz}=\Gamma\stackrel{y}{zy}=a'(z)
\Gamma\stackrel{z}{tt}=b'(z)e2b(z)
\Gamma\stackrel{z}{xx}=\Gamma\stackrel{z}{yy}=-a'(z)e2a(z)
\Gamma\stackrel{t}{tz}=\Gamma\stackrel{t}{zt}=b'(z)
\Gamma\stackrel{}{either}=0
<The Riemann curvature tensor>
R\stackrel{x}{zxz}=R\stackrel{y}{zyz}=-a''(z)-[a'(z)]2
R\stackrel{z}{tzt}=b''(z)+[b'(z)]2
I tried to find the Ricci scalar curvature(R) from current result, but it gave a function depend on z. Is there any problem in my calculation?
Thanks for answering this question~!
I didn't check your calculation, but why do you think the Ricci scalar shouldn't depend on z?
I got the same for the Christoffel symbols, but I got a lot more non-zero elements for the Riemann curvature tensor.
Sorry for that I did not write down the other non-zero terms of Riemann curvature tensor which can be deduced by symmetry and anti-symmetry properties.
However, I still have a contradiction that
Rt _ztz-b''(z)-[b'(z)]2
but
Rz_tzt=[b''(z)+[b'(z)]2]e2b(z)
Did you also get the same result?
I get
Rztzt = -[b''(z)+[b'(z)]2]e2b(z)
Thank you, I will check my result again
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
