Negative Pressure Wave generation due to pipeline leak
  • Thread starter Thread starter leakdetector123
    Pressure
The discussion centers on the generation of negative pressure waves due to pipeline leaks, exploring the mechanics of pressure transients, their propagation, and the underlying physical principles. The scope includes theoretical explanations and technical reasoning related to fluid dynamics and wave propagation in pipelines.
  • Some participants describe the negative pressure transient as analogous to water hammer, generated by a sudden increase in flow out of the transmission line.
  • There is a question regarding the reason why pressure waves propagate at the speed of sound in fluids, with one participant noting that this speed is influenced by temperature.
  • One participant proposes a model where a low pressure region created by a leak allows high-pressure molecules to move towards it, suggesting a mechanism for the propagation of the low pressure region.
  • Another participant confirms this model, stating it is a loss of support and elaborates on the influence of fluid temperature on molecular velocity and the propagation of pressure waves.
  • A differential force balance approach is mentioned, leading to a wave equation that indicates the characteristic speed of wave propagation is equal to the speed of sound.
  • There is a query about the compression of gas during a leak, with acknowledgment that the pipeline contains compressed gas.
Participants express multiple competing views regarding the mechanisms of pressure wave propagation and the effects of temperature and fluid dynamics. The discussion remains unresolved on certain aspects, particularly concerning the compression of gas and the detailed mechanics of pressure wave behavior.
Some assumptions regarding the behavior of gas under different conditions, such as adiabatic expansion and compression, are present but not fully explored. The discussion also touches on the influence of fluid flow velocity and the Doppler effect on pressure transients, which may introduce additional complexity.
leakdetector123
TL;DR
when leak happens in the pipeline a negative pressure wave is generated can anyone explain how it is generated and why in many research paper it is mentioned that this wave travels at sonic speed( speed of sound )?
consider a simple straight gas pipeline
please refer below attached file for further details
The negative pressure transient is generated by the sudden increase in flow, out of the transmission line.
It is the negative equivalent to water hammer, that is transmitted back up the line when a valve is suddenly closed.
The pressure wave propagates up the line at the speed of sound in the fluid.
is there any specific reason or explanation as for why pressure wave propagates at the speed of sound in fluid
The speed of sound is a function of temperature, because temperature determines the average velocity of the molecules in the fluid.
can you explain how this pressure transient travels
what i am thinking is that when leak happens a low pressure region is generated near the leak and the molecules in the high pressure region in pipeline travels to the low pressure region hence creates the low pressure region in the place where previously high pressure existed and so on this low pressure region travels across the pipeline
is that correct?
is that correct?
Yes. It is a loss of support.
The average kinetic energy of the molecules in the fluid, is proportional to temperature. The average velocity of the molecules in the fluid, is therefore proportional to the square root, of the fluid temperature.
The pressure waves, that propagate away from the burst of a pipeline, will also be influenced by the velocity of the fluid flow in the pipeline, immediately prior to the burst. That will introduce a Doppler effect, that will differentially scale the time axis for the transients, at the ends of the line. That may influence the cross-correlation process.
The attenuation of the transients, will also be dependent on travel time, through the fluid. That will change the amplitude scale of the transients. Cross-correlation will ignore the differential attenuation. That will result in the loss of any range information, that might have been present in the transient amplitudes.
If you do a differential force balance on the gas within the section of pipe between x and x +dx and assume that all gas expansion and compression occurs adiabatically, you end up with a wave equation for the pressure as a function of time and position. The characteristic speed of the wave propagation in this equation is equal to the speed of sound.
i understand when leak happens the gas expands but how does the gas compresses
The pipeline contains compressed gas.
  • · Replies 21 ·
  • · Replies 49 ·
