Negative to a Positive Gravitational Force
The discussion centers on the calculation of gravitational forces experienced by an aircraft transitioning from negative to positive G-forces. Specifically, when an aircraft experiences -2 G's and then shifts to +3 G's, the total force experienced is +3 G's, not +5 G's. This is due to the nature of G-forces being directional measures of acceleration, where the maximum acceleration is defined as +3 G's. The conversation highlights the importance of understanding the implications of force direction on structural integrity during flight maneuvers.
  • Understanding of G-forces in aviation
  • Basic principles of structural mechanics
  • Knowledge of aircraft dynamics
  • Familiarity with acceleration and its measurement
  • Research the effects of G-forces on aircraft structural integrity
  • Study the principles of static and dynamic loads on aircraft components
  • Learn about the role of G-forces in flight safety inspections
  • Explore advanced topics in aircraft maneuverability and performance metrics
Aerospace engineers, aircraft maintenance personnel, flight safety inspectors, and anyone involved in the analysis of aircraft performance under varying G-forces.
EA6BMech
I am with an aircraft squadron and we have a conditional inspection for aircraft that pull an excessive amount of "G's". The inspection is to check significant parts of the aircraft that might crack or buckle under certain amounts of stress. There is an arguemt in the shop about going from a negative "G" (Forces pulling in one direction) to a positive "G" (Forces pulling in another direction). If the aircraft is flying and is pulling -2 G's then changes direction and pulls +3 G's... How many "G's" were pulled. Some say 5 G's and others say 3 G's. Can someone help us out and maybe provide a reference for this issue? Thanks!
The change in force would correspond to a change of ~5G, but when going from -2g to +3g, the significance of the sign is the direction of force.
Take a beam fixed at two ends. Pushing up with 2g (-2g) would cause if to bow up. The top would be in tension and the bottom in compression at the point of loading. Then press down with 3g (+3g) and the beam bows downward, and the top is in compression and the bottom in tension under the point of load.
So with the reversal in acceleration, some parts will experience a change from compression to tension, or change in amount of tension, and a reversal of the direction of shear.
Is one referring to stationary parts or moving/rotatig parts?
We would be moving because we are flying in an aircraft. And just for simplicity we would just be going up and down. The debate is if you were flying in a negative G but then you change direction to put positive G on the aircraft. I do understand that a "G" force (- or +) is just directional (ie up or down such as on the "suspension beam" you used for a visual). Does this help?
Here is something else I would like to add just to get the point across. If you start at no G's and go to 3 G's then go from -2 G's to +3 G's... Are you still only putting 3G's of force on the aircraft?
The "G" is a measure of acceleration. If the plane was accelerating at -2Gs and then goes to +3Gs...then the maximum acceleration was +3G. If you plot a graph of velocity vs. time, and you derive the acceleration, the maximum acceleration will be +3G. If you look at the forces experienced by the airplane, the maximum will be 3x the force of gravity.
I can see how somebody might be tempted to add the accelerations and come up with 5Gs, but it doesn't work that way. You might as well accelerate at 3Gs for ten seconds, and then claim that you actually accelerated at 30Gs because 3x10 is 30...
11K
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 18 ·
11K
