Negative Voltage: Understanding How Current Travels
4 replies · 3K views · last reply
gbaby370
I just completed a problem regarding a Millikan Oil Drop Experiment. I ended up with a negative voltage in the solution.
I am just trying to understand negative voltage. Does it mean that the current will travel from - to + instead of the conventional + to -?
yes it does
phinds said:
yes it does
Umm.. I don't think so. Why would it do that? Conventionally signed current will always flow from the higher (more +ve) potential to the lower.
If the "-" represents the ground or reference then I believe the "+" can have any potential difference whether positive or negative. In such a case though the "-" terminal will have the higher potential and so conventional current will run from it to the "+" terminal.
Yeah, that's what I meant, but my simple "yes" was a bit misleading, as haruspex correctly pointed out.
