Net force acting on a charged particle ##+Q##
The net force acting on a central charge ##+Q## surrounded by twelve equally spaced charges ##+q## on a circumference of radius R is zero due to symmetry, as the forces from diametrically opposed charges cancel each other out. Removing one charge, specifically the one at "3 o'clock," results in a net force directed towards the charge at "9 o'clock," calculated using the formula ##\vec F= \frac {1} {4 \pi \varepsilon_0} \frac {q Q} {R^2} \vec R##. If both the "3 o'clock" and "9 o'clock" charges are removed, the system returns to equilibrium, with the net force being zero again. The discussion emphasizes the importance of vector addition and the superposition principle in analyzing forces in symmetrical charge distributions.
  • Understanding of Coulomb's Law and electric forces
  • Familiarity with vector addition and graphical methods
  • Knowledge of the superposition principle in electrostatics
  • Basic concepts of charge symmetry and equilibrium states
  • Explore the implications of removing multiple charges from symmetrical charge distributions
  • Learn about the graphical method for vector addition in physics
  • Investigate the effects of charge distribution on electric fields
  • Study the principles of electrostatic equilibrium in more complex systems
Students of physics, particularly those studying electrostatics, educators teaching electric force concepts, and anyone interested in understanding charge interactions in symmetrical arrangements.
Mutatis
Twelve equal particles of charge ##+q## are equally spaced over a circumference (like the hours in a watch) of radius R. At the center of the circumference is a particle with charge ##+Q##.
a) Describe the net force acting over ##+Q##.
b) If the charge located at "3'o'clock" has been taken off, what's the net force acting over ##+Q##?
c) If both charges located at "3'o'clok" and "9'o'clock" has been taken off, describe the force acting over +Q this time.
##\vec F= \frac {1} {4 \pi \varepsilon_0} \frac {Q_1 Q_2} {r^2} \vec r##
a) As the charges are equally spaced over that circumference, the net force acting over ##+Q## is zero, because the forcs diametrically opposed to each other cancel each other out.
b) If you take the "3'o'clock" particle out the circumference, the only particle that exerts force over ##+Q## is the particle diametrically oposed to "3'o'clock" particle: $$ \vec F= \frac {1} {4 \pi \varepsilon_0} \frac {q Q} {R^2} \vec R $$
c) The system back to equilibrium state.
What do you think guys? I'm not sure about my answers...
In (b) you say
Mutatis said:
... the only particle that exerts force over ##+Q## is the particle diametrically oposed to "3'o'clock" particle
Have the other particles stopped exerting forces on ##+Q##? Your conclusion is correct but your justification needs to be improved.
kuruman said:
In (b) you say
They're still exerting force over ##+Q##, but as they're are diametrically opposed to each other, so they cancel out. Right?
Right. As an enrichment to this problem, what would the net force on the central charge be if you had 11 equally spaced charges on the circumference instead of 12? Your cancellation in pairs argument will no longer work. What if you removed one of these 11 and were left with 10?
In the first case, the net force is going to be a sum of the individual contributions of each charge acting over ##+Q##, superposition principle. And then if I was left with 10 equally spaced charges the system is going to equilibrium state.
Sorry, you are incorrect on both counts, in fact you got it backwards. First draw the 11 force vectors acting on the central charge. Then add them using the "tail-to-tip" graphical method for adding vectors. What do you get? Also consider this. If you remove a charge from the distribution, the electric force at the center would be the same as the electric force from the old distribution plus a charge of opposite sign placed at the location of the charge that you removed. This is superposition. So if the old distribution gives zero force at the center, removing one ##+q## charge from the 12 o' clock position will provide at the center the force of a ##-q## charge placed at the 12 o' clock position.
If the arrangement is symmetrical, then the central charge cannot move in any direction, as you can rotate the system by ##2 \pi/11## and get an equivalent system where it is now moving in a different direction.
I'll try to write up this when I get home. This exercise have got my brain confused. At the first question that I've posted, would you, if you were my physics teacher, consider it right?
You need to say what that vector ##\vec{R}## means. Otherwise, it's fine.
The symmetry argument is, of course, applicable and correct in this case. More generally though, if the sum of the forces forms a closed polygon (regular or not) when drawn graphically, then that sum is zero. That's the connection that I wanted @Mutatis to establish.
