Net force between two identical dipoles
E&M
I need to find force between two dipoles. I was thinking of finding F between all the four charges separately and then using superposition principle to get the net charge. but is there an easier way. Say, if I use the formula of E (dipole) for one dipole and multiply it with the charges in another dipole and use superposition principle , will it work?
You can find the fields, and use superposition on the fields, and then multiply by the charge. The field of a dipole and also that of the other charge, that is.
but the question tells me to find net force on a second dipole. so, why do i need to find the field due to the charge in this case? i am even more confused.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
