Net force to stop a truck and car acceleration
10 replies · 5K views
thua
1. A 1.2 x 10^4 kg truck is traveling south at 22 m/s.
a) What net force is required to bring the truck to a stop in 330 m?
b) What is the cause of this net force?
Answer: a) 8.0 x 10^3 N [N]
2. Each of the four wheels of a car pushes on the road with a force of 4.0 x 10^3 N [down]. The driving force on the car is 8.0 x 10^3 N [W]. The frictional resistance on the car is 6.0 x 10^3 N [E]. Calculate the following:
a) the mass of the car
b) the car's acceleration
Answer: a) 1.6 x 10^3 kg b) 1.2 m/s^2 [W]
I have the answers to these two questions, but I really need help on how to understand and do it.
So far...
1. a) v = d/t
t = d/v
t = (0.33 km)/(22 m/s )
t = 0.015 s
a = v/t
a = (22 m/s )/(0.015 s)
a = 1466.7 m/s^2 ?? <====== stopped here because this makes no sense..
the time makes no sense... you are right :p
here is your problem
the distance has to be in meters...
If you've covered energy then that would be the best way to solve the problem. If not then the following equation should look familiar:
[itex]v_f^2 = v_i^2 + 2ad[/itex] which is what you should use to tackle this problem.
whozum... is that to find the acceleration?
(22 m/s )^2 = (0 m/s )^2 + 2a(330 m)
a = 0.73 m/s^2
f = ma
f = 8760 N <----- something's still wrong
if you want the truck to stop acceleration has to be negative...
that still doesn't work though because the net force comes up to -8670 N .
i think I'm totally missing out on something here...
The acceleration is not south but north, -8670 N = 8670N [N]. However I don't know why they have 8.0 x 10^3N as the answer, your answer of 8670 is alomst correct.
By the way the correct solution is
[itex]v_f^2 = v_i^2 + 2ad[/itex] you had the velocities mixed up.
[itex](0)^2 = (22)^2 + 2a(330m)[/itex]
[itex]a = \frac{22^2}{-660} = -0.733333 [/tex]<br /> <br /> [itex]F = ma = m(-0.7333333) = 8800N = 8.8 \times 10^3 N [N][/itex][/itex]
okay thankssss... and for number 2... i really don't know how itll work cause mass is equal to net force over acceleration, but all i have is net force... no acceleration... so how would that work out?
The force from the 4 tires is the weight of the car (normal force). You can find the mass from there.
does that mean that the answer is wrong again? because i came up with 16000 N which is 1.6 x 10^4 and they say its 1.6 x 10^3 kg.
and does 1 N equal to 1 kg... I am not very familiar with that.
but 1 N actually equals to 1 kg x m/s^2, though right?
