Balancing Net Ionic Equation: Mg + HC2H3O2 --> Mg(C2H3O2)2 + H2
  • Thread starter Thread starter francisco
    Ionic Net
The discussion focuses on balancing the net ionic equation for the reaction between magnesium and acetic acid. The balanced molecular equation is Mg (s) + 2HC2H3O2 (aq) --> Mg(C2H3O2)2 (aq) + H2 (g). The net ionic equation is derived by identifying and removing the spectator ion, resulting in Mg (s) + 2H(+) (aq) --> Mg(2+) (aq) + H2 (g). A clarification is made regarding the spectator ion notation, correcting it from (C2H3O2)2(2-) to 2C2H3O2(-). The thread also briefly shifts to another user seeking help with a different reaction involving magnesium and lead nitrate.
francisco
i need help with the following problem:
rewrite the following unbalanced equation, changing it to a balanced net ionic equation.
Mg (s) + HC2H3O2 (aq) --> Mg(C2H3O2)2 (aq) + H2 (g)
thanks.
francisco
i balance the equation:
then i write the equation, listing all the species present in solution.
Mg (s) + 2H(+) (aq) + (C2H3O2)2(2-) (aq) --> Mg(2+) (aq)
+ (C2H3O2)2(2-) (aq) + H2 (g).
i see that (C2H3O2)2(2-) undergoes no change during the reaction. it appears on both sides of the reaction arrow and acts merely as a spectator ion, whose only role is to balance the charge. the actual reaction, when stripped to its essentials, can be described more simply by writing the following ionic equation, in which the spectator ion
(C2H3O2)2(2-) is removed:
leaving the spectator ion (C2H3O2)2(2-) out of the net ionic equation merely implies that the specific identity of the spectator ion is not important: any nonreactive ion could fill the same role.
is this correct?
thanks.
francisco
Nicely done!
It is not a (C2H3O2)2(2-) but 2C2H3O2(-). Small, but very important difference.Borek
Hi everyone.I'm having some great trouble.I need to know how to write the net ionic equation for: Mg + Pb(NO3)2=Pb + Mg(NO3)2..
Please and thank you.
Start listing ions present in the solution.
12K
