Networking Virtual Machines: Best Practices
- Thread starter WWGD
- Start date
- Tags
- Machines Networking Virtual
9 replies · 3K views · last reply
Discussion
Mentor
- 15,835
- 10,722
Do you mean like Docker containers?
Homework Helper
- 7,926
- 13,240
Thanks, not sure exactly, but I am just looking to have them be able to share resources (I am thinking mostly Active Directory) and communicate with each other in general, as standard physical machines do.jedishrfu said:Do you mean like Docker containers?
willem2
- 2,134
- 395
search for (vmware/hyperv/whatever) + virtual (network/switch). Tons of info.
https://technet.microsoft.com/en-us...a-virtual-switch-for-hyper-v-virtual-machines
https://www.vmware.com/support/ws55/doc/ws_net_configurations_custom.html
stoomart
- 392
- 132
There are three types of virtual networks: Bridged, NAT, and Host-only. When you create a new VM or add a NIC to an existing VM, you assign the NIC(s) to a virtual network, thereby giving it access to any other VMs configured on the same network.
rkolter
- 97
- 39
WWGD said:Thanks, not sure exactly, but I am just looking to have them be able to share resources (I am thinking mostly Active Directory) and communicate with each other in general, as standard physical machines do.
Yes. You can put a VM on a network assuming the VM has access to a NIC card. That VM could be added to the domain, and you could log into that VM using accounts in the active directory for that domain. If you looked for computers on your domain, you would also find your VM. That VM would be able to access whatever resources a physical computer on that domain could access. It would be for all intents and purposes, just another computer on the domain.
There ARE differences. But, for the scope of your question - they aren't relevant.
newjerseyrunner
- 1,532
- 637
VMs are supposed to be agnostic to the hardware they are running on. As long as their ips are different, there should be no issue. Sometimes you'll have to use a bridged adapter through the host though.
Homework Helper
- 7,926
- 13,240
Thanks, Runner. Does the idea of having them in the same domain ( in windows) work in general too?newjerseyrunner said:VMs are supposed to be agnostic to the hardware they are running on. As long as their ips are different, there should be no issue. Sometimes you'll have to use a bridged adapter through the host though.
newjerseyrunner
- 1,532
- 637
Yeah, part of my job is to manage some of my companies windows servers. I've virtualized all of them and they're all on the same domain.WWGD said:Thanks, Runner. Does the idea of having them in the same domain ( in windows) work in general too?
As long as they each have their own ip and computer name. Ip you set in network and sharing, right click on the connection, properties, IPv4, properties. The computer name, right click on my computer and a select properties.
- m_krispy
- · Replies 5 ·
- Computing and Technology
- Replies
- 5
- meld2020
- · Replies 7 ·
- Mechanical Engineering
- Replies
- 7
- E01
- · Replies 1 ·
- General Math
- Replies
- 1
- cdux
- · Replies 6 ·
- Biology and Medical
- Replies
- 6
- H2Bro
- · Replies 4 ·
- STEM Academic Advising
- Replies
- 4
- dpage
- · Replies 9 ·
- Chemistry
- Replies
- 9
- misgfool
- · Replies 7 ·
- General Engineering
- Replies
- 7
- kateman
- · Replies 3 ·
- Chemistry
- Replies
- 3
