New at pspice guidance will be appreciate
  • Thread starter Thread starter Dexterous
    Guidance Pspice
4 replies · 2K views
Dexterous
Hello I am new at pspice and actually i know only how to place parts and wire them..
this is the circut
and this is what i did so far
i need to know the voltage and the power on R1.
i don't really know where should i start :/
thx.
Is your question regarding how to use pspice or are you just trying to answer a circuit analysis question (and perhaps thought using pspice would be simpler than thinking about the circuit for a moment :wink:)?
If the former, your VCVS is wired backwards.
im trying to learn how to use pspice actually :]
i have a course with a final project at the end of the semester..
do i need to define the voltage source as a variable or somthing?
and what about R1 is there any definition i should do?
Make the correction to the VCVS (the input and output terminal wiring should be swapped). Double-click (or something) the VCVS symbol to set the gain property to what you want. That's pretty much all I can suggest. I suppose you can insert voltage, current probes at appropriate places to make measurements, etc. Answer the question using standard analysis techniques so you can compare with the pspice results.
