Newtonian Mechanics - Particle in Motion with Air Resistance
The discussion focuses on solving a physics problem involving a particle sliding down an inclined plane with air resistance modeled by the force f = kmv². The correct expression for the time required to move a distance d from rest is t = [arccosh(e^(kd))]/√(kgsin(θ). The participant initially attempted to derive the time using the equation ma = mgsin(θ) - kmv² and reached an incorrect form involving arctan. After clarification, it was confirmed that the correct function to use is arctanh, leading to the proper solution.
  • Understanding of Newton's Second Law (F = ma)
  • Familiarity with differential equations
  • Knowledge of kinematics and motion under gravity
  • Concept of air resistance modeled as f = kmv²
  • Study the derivation of motion equations under air resistance
  • Learn about the integration techniques for differential equations
  • Explore the implications of hyperbolic functions in physics
  • Investigate the effects of varying angles of inclination on particle motion
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in the dynamics of motion with resistance forces.
derravaragh
A particle of mass m slides down an inclined plane under the influence of gravity. If the motion is resisted by a force f = kmv^2, show that the time required to move a distance d after starting from rest is
where θ is the angle of inclination of the plane.
F = ma
F_g = mgsin(θ)
Resistance = -kmv^2
Motion of particle => ma = mgsin(θ) - kmv^2
My attempt was to set up the equation for the motion (ma = mgsin(θ) - kmv^2) and use differential equations to solve. After dividing by mass, I had:
dv/dt = gsin(θ) - kv^2
which I then divided by k, and substituted (g/k)sinθ for C^2 giving
dv/kdt = C^2 - v^2
After collecting terms and integrating I came to
t = arctan(v/√((g/k)sinθ))/√(kgsinθ)
I thought I was on the right track as I have the numerator correct, but I do not know where to go from here, or if this is even correct so far. Any help would be much appreciated. Also, I know this question has been asked before, but the answer given didn't make sense to me so it doesn't help.
Try writing the acceleration as ##a = \frac{dv}{dt} = \frac{dv}{dx}\frac{dx}{dt} = v \frac{dv}{dx}## where ##x## is distance along plane. Separate variables and integrate to find ##v## as a function of ##x##. Then, writing ##v = \frac{dx}{dt}## you can separate variables again and integrate to find ##t## as a function of ##x##.
[EDIT: Actually, your way works too. However, I think there is a typo in your final expression for t. Did you mean to write arctanh rather than arctan? If you solve your (corrected) expression for ##v## and then let ##v = \frac{dx}{dt}## you can separate variables and integrate to find ##t## as a function of ##x##]
Yes, it was supposed to be arctanh (and also denominator was correct not numerator). I just finished this, thank you very much for your assistance.
  • · Replies 24 ·
