Newtons 3rd Law (Ropes, Pulley)
6 replies · 3K views
PhysicsNoob76
A 2.5 kg mass is attached to a 3.5 kg mass by a light string that passes over a friction-less pulley. The masses are released.
a) What is the magnitude of the acceleration of the masses?
b) What is the tension in the string?
(I think) Ft - mg = ma
I drew 2 free body diagrams for both the weights and they both have Fg and Ft on the y.
On this 6th line, starting with (2.5)(a)... I made it so that Ft2 = Ft2
My answer was suppose to be 6.54 m/s in the work I showed because the acceleration of the bigger weight will accelerate negatively. So ignore the minus sign for my answer to a =
I think I've done the best I could, but my answer is still wrong, not sure why.
lewando said:
The magnitude of the acceleration will be the same, but in opposite directions.
Yeah, I knew that, I should have included that too. I need actual with with the question though.
You have 2 equations, 2 unknowns (one needs fixing-- one of the masses should be accelerating upwards-- use "a", the other, downwards-- use "-a"). Solve for a.
I've done some changes, but I am still getting it wrong...
lewando said:
Since the heavier one is accelerating downward, replace "a" in line 2 with "-a". Try again.
Ohhhhhhh, thank youuuuuuuuuuuuu. I re-did my whole thing and now it works!
