Newton's law of gravitation, energy and centre of mass question
  • Thread starter Thread starter mrpurpletoes
The discussion revolves around Newton's law of gravitation, specifically exploring the relationship between gravitational forces, energy, and the center of mass in a two-body system. Participants are examining different approaches to solving a problem involving the velocities and accelerations of two masses under gravitational influence.
  • Mixed
  • Participants are exploring various methods, including the original poster's attempt to apply energy conservation principles and the conservation of momentum. There are questions regarding the differences in results obtained from these approaches.
Some participants are seeking clarification on the original poster's method and expressing confusion about the discrepancies in answers. There is acknowledgment of the conservation laws suggested by the professor, but uncertainty remains about the application of these concepts in the context of the problem.
Participants are discussing the implications of using different approaches, particularly the distinction between energy conservation and momentum conservation, and how these relate to the forces acting on the two masses. There is mention of the velocities of the masses and how they affect the outcomes of the calculations.
mrpurpletoes
two point sized objects of mass 2kg and 10kg are at rest when kept at an infinite distance from each other. at some time, the velocity of the 10kg object is 2 m/s towards the 2kg object, find the velocity of the 2kg object at that time.
F=GmM/r^2
our professor told us to solve this using the fact that the velocity of centre of mass (com) will be 0, however before he said this i had taken a different approach and did this:
ma=GmM/r^2
m(dv/dr)*(dr/dt)= Fg (taking GmM/r^2 as Fg for now)
1/2(mv^2)= Fg dr
and since for M force= -Fg
1/2(Mv^2)=-Fg dr 1/2(mv^2)+ 1/2(Mv^2)=0, however, using this i get a different answer than when using the velocity of com=0, could someone explain please?
I'm not sure what your approach is. Are you proposing to do some integration?
Using a conservation law (I would have used conservation of momentum in this case) avoids having to integrate.
yes, our professor said to use conservation of momentum/ conservation of velocity of com, and i understood the method and the reasoning behind it, the part im facing a problem with is, why upon using the method i used am i getting a different answer.
I don't understand your method.
sorry ill try to make it clearer, (Fg=GmM/x2) (assuming velocity of M to be V and velocity of m to be v at a point)
for the mass M
Ma= Fg
M(dV/dt)= Fg
M(dV/dx)*(dx/dt)=Fg
M(dV/dx)*V=Fg
MVdV=Fg*dx
MV2/2=Fg*dx .....(1)
for the mass m
m(-a)= -Fg
m(dv/dt)= Fg
m(dv/dx)*(dx/dt)=Fg
m(dv/dx)*v=Fg
mvdv=Fg*dx
mv2/2=Fg*dx ......(2)
so from (1) and (2)
mv2/2 should be equal to MV2/2, however when i use these two equations to find the solution i am getting a different answer than when i use conservation of momentum.
for the mass M
Ma= Fg
M(dV/dt)= Fg
M(dV/dx)*(dx/dt)=Fg
M(dV/dx)*V=Fg
MVdV=Fg*dx
for the mass m
m(-a)= -Fg
m(dv/dt)= Fg
m(dv/dx)*(dx/dt)=Fg
m(dv/dx)*v=Fg
mvdv=Fg*dx
so from (1) and (2)
Kinetic energy depends on a force acting over a distance. Not over time. The ##dx## in your two cases are different. The large mass accelerates more slowly than the small mass, so ##dx_M/dt## will be less than ##dx_m/dt##.
Momentum depends on a force acting over a time. If the force has the same magnitude on each mass, then the magnitude of the momentum of each mass stays the same.
thanks a lot dude o7
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 42 ·
  • · Replies 27 ·
