Newton's Law of Gravitation ratio
The discussion focuses on determining the optimal ratio of mass m to total mass M that maximizes the gravitational force between two separated masses. The gravitational force is expressed using the formula F=Gm1m2/d^2. Through analysis, it is established that the ratio m/M that maximizes the gravitational force is 1/2, derived by taking the derivative of the function Mm - m^2 and setting it to zero, leading to the conclusion that M=2m.
  • Understanding of Newton's Law of Gravitation
  • Familiarity with calculus, specifically derivatives
  • Knowledge of gravitational force equations
  • Basic algebra for rearranging equations
  • Study the implications of gravitational force maximization in physics problems
  • Learn about the applications of derivatives in optimization problems
  • Explore variations of gravitational force equations in different contexts
  • Investigate the concept of gravitational potential energy and its relationship to force
Students studying physics, particularly those focusing on gravitational forces and optimization techniques, as well as educators looking for examples of applying calculus in physical scenarios.
brendan3eb
A mass M is split into two parts, m and M - m, which are then separated by a certain distance. What ratio m/M maximizes the magnitude of the gravitational force between the parts?
F=Gm1m2/d^2
I first just tried plugging in M - m and m in for m1 and m2 to see what I get.
F=(GMm-Gm)/d^2
I believe that I will have to take a derivative to find the maximum, but I am confused as to what I should take the derivative with respect to.
you should not need a derivative. look at extreme cases. if the ratio of M/m was 1000, what would the force be like? what if the ratio was smaller, say 2?
That is true, but I need to prove that is 1/2. The only way I can think of doing that is with a derivative. Although I do see the logic in what you are saying about taking the extreme cases.
try assigning integers to the variables M and d, since they do not change based upon different m values. also, recheck the GMm-Gm part of the equation. I got something else for if i plugged in the values like you did.
Starting with the regular equation for the force of gravity:
F=G\frac{m_0m_1}{d^2}
Let m_0=M-m and m_1=m
Substitute into the first equation:
F=G\frac{(M-m)m}{d^2}=G\frac{Mm-m^2}{d^2}
To maximize F, Mm-m^2 has to be maximized.
Take its derivative with respect to m and set it to zero:
M-2m=0
Rearrange:
M=2m
Rearrange:
\frac{1}{2}=\frac{m}{M}
  • · Replies 19 ·
  • · Replies 42 ·
