What is the magnitude and direction of the applied force?
  • Thread starter Thread starter Paymemoney
The discussion revolves around calculating the magnitude and direction of the applied force on a 1.25kg object that accelerates from 17.4 m/s to 26.8 m/s at an angle of 34 degrees over 3.41 seconds. The initial and final velocity components were analyzed, resulting in a horizontal component of 39.62 m/s and a vertical component derived from the sine of the angle. A calculation error was identified in determining the change in velocity, particularly in the vertical component, which starts at zero. The correct approach involves finding the change in both horizontal and vertical components separately. Ultimately, the force was calculated to be 16.65 N, but the user sought clarification on the vertical component's contribution to the overall force.
Paymemoney
A 1.25kg object is moving in the x direction at 17.4m/s. Just 3.41s later, it is moving at 26.8m/s at 34.0 degrees to the x-axis. What are the magnitude and direction of the force applied during this time?
F=ma
Firstly i drew a diagram and it was in vector components so i calculated the resultant.
1st component
H: 17.4m/s
V: 0m/s
2nd component
H: 26.8cos(34)
V: 26.8sin(34)
Resultant component:
Horizontal = 17.4 + 26.8cos(34) = 39.62 m/s
Vertical = 26.8sin(34)
so \sqrt{39.62^2+22.22^2}
direction Resultant = tan^{-1}(\frac{22.22}{39.62})
direction = 30 degrees
find the magnitude F = m * \frac{v}{t}
F = 1.25 * \frac{45.43}{3.41}
F=16.65N
This is incorrect can someone tell me where i have gone wrong.
P.S
You have to find the change in horizontal component of velocity (vf - vi)
is this the same in the vertical component?
edit never mind its not the same
Yes. But initial vertical component of the velocity is zero.
