Newton's second law dp/dt version?
The discussion clarifies the momentum version of Newton's second law, specifically the relationship between force, mass, and acceleration. It establishes that the force can be expressed as F = dp/dt, where p is momentum defined as p = mv. The participants confirm that acceleration is the second derivative of position, a = d^2x/dt^2, and emphasize the importance of the product rule in differentiation when mass is constant, leading to F = ma.
  • Understanding of Newton's laws of motion
  • Familiarity with calculus, specifically differentiation
  • Knowledge of momentum and its relation to mass and velocity
  • Concept of derivatives, including first and second derivatives
  • Study the product rule in calculus for differentiation
  • Explore the implications of Newton's laws in various physical systems
  • Learn about the chain rule and its applications in physics
  • Investigate the concept of conservation of momentum in closed systems
Students of physics, educators teaching mechanics, and anyone interested in the mathematical foundations of motion and forces.
Steve Drake
Hello,
I am confused by the momentum version of Newtons second law...
So we know
\bar{F}=m\bar{a}=m\left(\frac{d\hat{v}}{dt}\right)
and that
\bar{\rho}=m\bar{v}=m\left(\frac{d\bar{x}}{dt}\right)
so is
\frac{d\bar{p}}{dt}=m\frac{d\left(\frac{d\bar{x}}{dt}\right)}{dt}
What I mean is this bit \frac{d\left(\frac{d\bar{x}}{dt}\right)}{dt} somehow equal to \bar{a}
Thanks
Science news on Phys.org
Yes, since acceleration is the (first order) time derivative of velocity and velocity is the (first order) derivative of position, the acceleration is said to be the second order derivative of position, which can be written as ##a = \frac{d^2x}{dt^2}##
You can read more about other notations for higher derivatives on [1]
[1] https://en.wikipedia.org/wiki/Derivative
Force F = dp/dt, this result summarizes Newton's first/second law, to prove this, we know that F = ma = m*dv/dt, mass is invariant so we can treat it as a constant, which yields to m*dv/dt = d(m*v)/dt = dp/dt, If no force is acting on an object F = 0 = dp/dt, p is constant from which it follows Newton's first law and momentum conservation, Good luck :p
Steve Drake said:
Hello,
So we know
and that
Using the product rule:
\vec{F} = \frac{d\vec{p}}{dt}=\frac{d}{dt}(m\vec{v}) = m\frac{d\vec{v}}{dt} + \frac{dm}{dt}v
If m is constant, dm/dt = 0 so:
\vec{F} = m\frac{d\vec{v}}{dt} = ma = m\frac{d}{dt}v = m\frac{d}{dt}(\frac{d\vec{x}}{dt})
AM
Thanks guys, forgot about the chain rule for differentiation.
So in general, whenever there is a \frac{d^{2}}{dx} then it can be thought of two separate derivatives, each giving their own result. But the ^2 means it skips the first result and we go right to the second?
Actually, I misspoke. It is the product rule not the chain rule. I have corrected the error.
The ##\frac{d^{2}x}{dt^2}## signifies the second derivative with respect to time - the derivative with respect to time of (the derivative with respect to time of x).
AM
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 23 ·
