Newton's Second Law. Involving an airplane.
2 replies · 5K views · last reply
Trevor Mock
An airplane goes into a turn 3.6km in radius. If the banking angle required is 28 degrees from the horizontal, what is the plane's speed?
Newton's Second. The only forces acting on the plane are gravity and the normal force. This isn't given in the question, it is just obvious. Neglect friction.
My main problem is drawing the free body diagram. I really need help with this problem. A clean, clear thorough explanation. Show every step please!
The answer is 490km/h. I just don't know how to arrive at the answer.
Hello Trevor Mock,
Welcome to Physics Forums! :smile:
Are you sure you didn't leave something out of the problem statement, such as the the vertical component of the plane's acceleration (even if it happens to be zero)? (In other words, is the plane accelerating in the up or down direction? Or does it maintain a constant vertical component of velocity?)
Please read the "Guidelines for students and helpers" post at the top of this subforum (it's a sticky at the top of the Introductory Physics Homework subforum). It's you that must show your steps. :wink:
Anyway, some general guidance, list out all the forces acting on the plane. In this particular problem, two of those forces are important. The solution is possible once you make a particular assumption about the plane's vertical acceleration. You should be able to put the two important forces together, along with the "normal" force, to form a triangle.
