GAsahi said:Repeating the same error ad nauseaum doesn't make it right. Your so-called "counter-example" has the source and the emitter at rest wrt each other.
Whether two objects are at rest wrt each other is a COORDINATE-DEPENDENT fact. In Rindler coordinates, two clocks at different values of the X coordinate are at rest relative to one another. In inertial coordinates, they are not at rest relative to one another.
You are desperately trying to prove that the method does not apply when the emitter and the detector are moving wrt each other
It clearly doesn't. You know that's the case. If the receiver and the sender are at the SAME height, and are moving relative to one another, then there will be a nonzero redshift. The redshift formula in that case is not the same as the position-dependent gravitational time dilation formula. I can't believe you're disputing that.
(you changed the goal posts when I showed you that the method works when there is no relative motion). The GPS calculations , as posted by Ashby, disprove your statement.
No, they DON'T. They are in complete agreement. What is true is that the Schwarzschild relative clock rate calculation gives the same answer as the redshift calculation in the case where the sender and receiver are stationary in the Schwarzschild coordinates. If they are NOT stationary in the Schwarzschild coordinates, then there is an additional Doppler effect that must be taken into account. Are you seriously disputing this?
