Mentor
- 51,032
- 27,075
stevendaryl said:I said that it was your method that was incorrect
The general method he used is correct, provided you adopt the particular coordinates and simultaneity convention he adopted. (The particular derivation he gave was for a special case, yes.) If you are saying those coordinates and that simultaneity convention are not the only possible ones, that's true; and in different coordinates you would use a different method for defining "relative clock rates". An observer on a satellite in low Earth orbit, for example, would see Earthbound clocks (clocks at rest on the Earth's surface and rotating with it) to be "running slow" if he used his own local inertial coordinates; but in the ECI frame his clocks would be "running slow" relative to Earthbound clocks (I believe that's right for low enough orbits--the GPS satellite orbits are very high, 4.2 Earth radii IIRC). However, the observed frequency shift for light traveling between the two observers would be independent of which coordinates you adopted.
