Nodal analysis conventions and current direction assumptions
9 replies · 4K views · last reply
jpruim
I've been assigned the following problem for homework in my Electrical Engineering class:
Circuit schematic for a nodal analysis problem: nodes V1, V2 and V3 with resistors 40 ohm, 20 ohm, 10 ohm, 100 ohm and 50 ohm, an 8V source and a 6V source, and current io marked with an arrow.
*Note, the duplicate v2 is supposed to be v3.
But I keep getting
v1 = 4.10V
v2 = 4.81V
v3 = -1.19V
and
i0 = 52.9mA
Every simulator I've put this into says it's wrong, yet I've attempted solving it about 12 times (consuming almost all my remaining notebook pages) and still get the same answers.
I can't post a copy of my written work since I currently don't have access to a scanner. However, I drew in arbitrary current directions and made sure to respect them for all calculations using KCL.
I have no idea what I'm doing wrong at this point. My professor just seems to get agitated when I ask what the convention is and his general response is "just do the current thing" or something vague like that. I don't think anyone in my class actually understands how to do this (except the class-repeaters).
I've been told by my friend to "always assume currents flow into a node. Ignore what's drawn. they always flow into nodes", but I've tried that at least 4 times. I've never gotten the answers my simulator provides me, regardless of how I solve it.
Is there any "convention" to solving these? Can anyone tell me what error I'm making so I don't make the same error on my exam?
Circuit schematic with nodes labelled V1, V2 and V3, resistors 40Ω, 20Ω, 100Ω and 50Ω, a 6V source, an 8V source, and current io marked by an arrow in the top wire.
But I keep getting
v1 = 4.10V
v2 = 4.81V
v3 = -1.19V
and
i0 = 52.9mA
We can't tell you what you are doing wrong, since you didn't post your work.
It would help if you included your nodal equations or KCL equations. You shouldn't need a scanner for that.
Handwritten nodal analysis on lined paper with node voltage equations involving V1, V2 and V3 over resistors of 40, 20, 10, 100 and 50, ending with a boxed solution V1 = 4.10 V, V2 = 4.81 V, V3 = -1.19 V and I0 = 52.4 mA.
There we go. the lighting in my room is terrible and I wasn't sure if a picture would turn out correctly. This one used directions I arbitrarily assigned and calculated from.
At node 2 you are considering a current in from the left, a current in from the right, and a current exiting downwards.
The current into node 2 from the right can be seen to be the sum of the two other currents entering node 3, viz., (V1-V3)/100 + (0-V3)/50[/color]
I can see at least a couple of sign issues in your work. But the main thing is that you're making your life difficult and prone to errors by mixing currents flowing in and flowing out of a node in the same KCL equation. This can be done, but it takes a lot of concentration to keep all the signs straight.
A better approach is to pick one direction, either flowing in or flowing out of the node, and write each term accordingly. That way every term is added, never subtracted. The single exception is for current sources where they dictate the current direction; Then you need to be careful of the sign of the term so that it matches the "in" or "out" paradigm that you've chosen.
In the sixth line of your work you transported the "-12" to the RHS but didn't change the sign. In the next line where you write the v2 node equation you've mixed up the current directions so the sum is unlikely to be zero. And in fact I can confirm that the result is not a correct node equation.
When you say to pick one direction, I should respect those defined directions at other nodes they affect (ex. if I say current flows into v1 from v2, I have to say it flows out of v2 in my KCL equation for v2 [subtracting it instead of adding it]), or can I sum all the currents at each node?
You can treat every node independently with regards to choosing a direction paradigm. Multiplying an equation through by a constant doesn't change the equation, and -1 is a perfectly good constant :smile:
So you can write "in" equations for every node, or "out" equations for every node, or even a mixture. But be consistent for individual nodes.
When respecting that direction, I assume I also have to reflect it in my ohm's law formulas? (ex. if I say all currents are flowing into v2, I would have to consider v2 as the "lower potential" and v1, v3 as "higher potential" [v1 - v2/20] and so on?)
Right.
Personally (my own habit) is to always choose "out" as my direction of choice. So if I'm writing an equation for node "v1", every term that's not a fixed current will have the form ##\frac{v1 - <stuff>}{<stuff>}##.
gneill said:
Right.
Ah. That helps. When it was explained to me, I was told I had to keep the current directions constant, so that's why I have the mix of ins and outs, but knowing I can use just addition or just subtraction is very helpful.
