Noether theorem and angular momenta
LCSphysicist
Consider the invariance of a vector field by rotation, whose transformation is given by ##x_{\mu'} = x_{\mu} + \epsilon^{v}_{\mu} x_{v}## , with ## \epsilon^{v}_{\mu} = - \epsilon^{\mu}_{v}##. Determine the Noether current and the conserved magnitude.
(OBS: Don't take the index positions too literal...)
Generally it is easy to deal with these type of exercises for discrete system. But since we need to evaluate it for continuous, i am a little confused on how to do it.
Goldstein/Nivaldo gives these formulas:
Two equations in plain math: delta x^v = epsilon_r X^v_r, and delta eta_rho = epsilon_r Psi_{r rho}.
Equation (13.148): d/dx^v of the quantity in braces, (∂L/∂η_{ρ,ν} η_{ρ,σ} − L δ^ν_σ) X_r^σ − (∂L/∂η_{ρ,ν}) Ψ_{rρ}, equals 0.
I am trying to understand how do we manipulate it here to get the conserved quantity.
So supposing the field is invariant (it is necessary, right?) ##\psi = 0##.
I think we can write our transformation as ##x_{i'} = x_{i} + \epsilon_{i j} x^{j} \theta##
So the current would be $$(\frac{\partial L}{\partial n_{p,v}} n_{p,\sigma} - L \delta ^{v}_{\sigma}) \epsilon_{\sigma j} x^{j} = (\frac{\partial L}{\partial n_{p,v}} n_{p,\sigma} \epsilon_{\sigma j} x^{j} - L \epsilon_{v j} x^{j}) $$
And the conserved charge $$ (\frac{\partial L}{\partial n_{p,0}} n_{p,\sigma} \epsilon_{\sigma j} x^{j} - L \epsilon_{0 j} x^{j}) = (\pi _{p} n_{p,\sigma} \epsilon_{\sigma j} x^{j}) $$
Is that right? I was expecting a epxression similar to angular momentum, but i was not able to achieve any!
No, it is not necessary for the field to be invariant. However, unless specified otherwise, it is probably what is assumed.
We cannot because the variation of the coordinates depend on the coordinates themselves. In order to find what the transformation actually is you must integrate the differential equation
\frac{dx^i}{ds} = \epsilon^i_j x^j.
Compare this to an explicit rotation in two dimensions ##\delta x = -y## and ##\delta y = x## for which
x \to x \cos(s) - y\sin(s), \quad y \to x\sin(s) + y\cos(s)
rather than
x \to x - ys, \quad y \to y + xs.
However, this is irrelevant for the issue at hand since to find the conserved current we only need ##\delta x^i##.
Yes, although note that your reference is using ##\eta## rather than ##n##.
Assuming that you defined the canonical momenta fields
\pi_p = \frac{\partial L}{\partial (\partial_t\eta_p)}
then yes.
Let us consider linear translations ##\delta x^i = k^i## rather than rotations. The corresponding Noether current would then be
J^i = \left(\frac{\partial L}{\partial(\eta_{p,i})} \eta_{p,j} - L\delta^i_j\right) k^j = T^i_j k^j
where ##T^i_j## are the components of the canonical stress-energy tensor. (Note that the canonical stress-energy tensor is not symmetric unlike the gravitational stress-energy tensor that is obtained by varying the action with respect to the metric in GR.)
Now, the interpretation of ##T^i_j## is "the ##i## component of the conserved current associated with invariance under translations in direction ##j##" and therefore we can consider ##p_j = T^0_j## to be the momentum density in direction ##j##. Consequently, your expression for the conserved current under rotations turns into
J^i = T^i_j \epsilon^j_k x^k,
with charge density
J^0 = p_j \epsilon^j_k x^k
which very much looks like an angular momentum density. For example, considering the ##xy## rotation mentioned earlier, we would have
J^0 = p_x \delta x + p_y \delta y = p_y x - p_x y.
Edit: Minor ##\LaTeX## fixes.
