Non commutator of symmetries giving rise to a gauge symmetry
The discussion revolves around the implications of non-commuting symmetries in a Lagrangian framework, particularly focusing on how such symmetries might lead to new conserved charges or currents as per Noether's theorem. Participants explore the relationship between symmetries, their commutation relations, and the associated Noether charges, while seeking clarity on terminology and frameworks relevant to these concepts.
  • One participant suggests that if two symmetries A and B do not commute, it may lead to a new symmetry and thus an associated conserved charge or current, but expresses difficulty in finding references on this topic.
  • Another participant counters that the non-commutation of symmetries does not necessarily imply the emergence of a new symmetry, providing the example of the commutator between translations and rotations generating a new translation within the algebra so(3).
  • A follow-up question seeks a method to determine the existence of a 'new' symmetry from the commutators without direct computation.
  • One participant mentions that the structure constants of the Lie algebra may provide insight into the relationships between symmetries.
  • There is a discussion about whether the charge or current associated with a new translation can be expressed in terms of the known charges or currents from the original translations.
  • Another participant expresses confusion regarding the terms "original" and "new" translations, emphasizing that there are a limited number of generators and that each generator corresponds to a Noether charge that follows the same algebra.
  • Clarification is sought regarding the terminology and the implications of the example provided, with a request for more context to better understand the inquiry.
Participants exhibit disagreement on the implications of non-commuting symmetries, with some asserting that they can lead to new symmetries and others arguing that this is not necessarily the case. The discussion remains unresolved regarding the criteria for identifying new symmetries from commutation relations.
Participants reference the structure constants of Lie algebras and the relationship between generators and Noether charges, indicating a potential complexity in the algebraic structure that may influence the discussion.
binbagsss
If there are two symmetries of a Lagrangian, perhaps they are transformations, A and B, and they don't commute ##[A, B] \neq 0##. Let this act on some field, then if ##(BA) ^{-1}AB## does not return the original field, i.e. if ##(BA) ^{-1}AB \neq \mathbb{1}##, then this gives a rise to a new symmetry so it will have an associated charge/ current by Noethers theorem. I feel like this is a common occurrence but I can't find any references on considering this as a symmetry/computing an associated conserved charge/current. Is there certain terminology/framework I need to be searching for? Thanks
binbagsss said:
If there are two symmetries of a Lagrangian, perhaps they are transformations, A and B, and they don't commute ##[A, B] \neq 0##. Let this act on some field, then if ##(BA) ^{-1}AB## does not return the original field, i.e. if ##(BA) ^{-1}AB \neq \mathbb{1}##, then this gives a rise to a new symmetry ...
Not necessarily so. E.g. the commutator between translations and rotations gives a new translation.
In the algebra ##so(3)## one has
##[L_i, L_j] = i \epsilon_{ijk} L_k##
so
##[L_1, L_2] = i L_3##
i.e. the commutator ##L_1## and ##L_2## generate the third symmetry generated by ##L_3##. But those three generators span the whole algebra, so we only need to look at the corresponding conserved charges of those generators.
so
ok thanks, I will check the translation and rotation one you say. Is there a way to know whether there will be a 'new' symmetry or not from (BA)^{-1} AB from the Lie algebra of the commutators without having to verify and compute each time?
I guess those are given by the structure constants of the Lie-algebra.
"Not necessarily so. E.g. the commutator between translations and rotations gives a new translation."
So here you are saying that this can be written in terms of the known translations and so the charge/current associated with the new translation would be able to be written in terms of the known charges/currents associated with the original translations?
I don't understand what you mean by "original" and "new" translations. There are only 4 of them (or D, in D spacetime dimensions if you're a string- or sugra-theorist). To every generator you can assign a Noether charge, and these Noether charges obey the same algebra as the generators.
"so. E.g. the commutator between translations and rotations gives a new translation." is what I meant by it. Obviously it's a simple case but I am asking for the purposes of thinking about other cases. obviusly I am aware its not a *new* translation.
Ah yes, sorry, that can be confusing. But I still don't understand your precise question. Maybe you can provide some more context.
  • · Replies 26 ·
