Non-constant acceleration not sure how to solve
  • Thread starter Thread starter anthonytw
    Acceleration
7 replies · 8K views
anthonytw
I'm not certain how to solve this, as the acceleration is not constant and dependent on the velocity. Here's the problem:
The acceleration of a marble in a certain fluid is proportional to the speed of the marble squared, and is given (in SI units) by a = -3.10v^2 for v > 0. If the marble enters this fluid with a speed of 1.35 m/s, how long will it take before the marble's speed is reduced to half of its initial value?
I take it I need to integrate the acceleration function, but I don't know how when I have dv/dt = -3.10 (dx/dt)^2. As this is just an introductory physics class and we are barely two weeks in, I'm wondering if there's not a simpler way to look at this. Any help pushing me in the right direction would be extremely appreciated!
You have complecated the problem by writing v = dx/dt.
You need a differential equation, witch connects v and t.
Leave v as it is and write a = dv/dt. You have a simple integral to do.
Hope this helps,
Gamma.
I haven't learned differential equations yet. Is there no other way to solve it? I tried moving the v and dv to one side and the constant and dt to the other and solving it like that, but that didn't work..
Nevermind, I got it using the method I said didn't work above.
Is the answer about 0.239 seconds? (sorry, heh, but I'm trying to immerse myself in physics and I want to check my work)
Your differential equation comes in the form of a simple harmonic motion.
d^2x/dx^2-bdv/dt=0 is the equation you need to solve i think
you will get something like x=bAsin{wt} I think but don't quote me on this where b is the -3.10
you should be then able to change it around to get your answer
a = -3.10v^2
dv/dt = -kv^2 (k=3.10)
separation of variables,
dv/v^2 = -kdt
-1/v = -kt +C
No sinusidal solution.
ahhhh yes you are right
i apologise i thought there was something wrong
