Non-homogeneous differential equation
The discussion centers on solving the non-homogeneous differential equation (x^2)y'' - 2xy + 2y = (x^3)sin(x). The original poster incorrectly identified the homogeneous solutions as (C1)e^x + (C2)e^2x, which do not satisfy the equation. The correct approach involves recognizing this as an Euler-Cauchy equation, transforming it using the substitution t = ln(x), leading to the correct homogeneous equation y'' - 3y' + 2y = 0, with solutions y1 = x and y2 = x^2. The Wronskian should be recalculated based on these correct solutions.
  • Understanding of Euler-Cauchy differential equations
  • Familiarity with Wronskian calculations
  • Knowledge of solving non-homogeneous differential equations
  • Ability to perform variable substitutions in differential equations
  • Study the method of solving Euler-Cauchy equations in detail
  • Learn how to compute the Wronskian for given solutions
  • Explore techniques for solving non-homogeneous differential equations
  • Practice variable substitution methods in differential equations
Mathematics students, educators, and professionals dealing with differential equations, particularly those focusing on non-homogeneous and Euler-Cauchy types.
kasse
How can I solve (x^2)y'' - 2xy + 2y = (x^3)sinx ?
I've used Euler-Caucy to find the homogeneous eq. (C1)e^x + (C2)e^2x. Then I've calculated the wronski (either e^3x or -e^3x depending on which function is y1 and y2). The rest involves solving the integral of xsin(x)/e^x and xsin(x)/e^2x, whics seems quite difficult. Am I on the right track?
You've done that wrong. If y= ex, then y'= y"= ex. Putting those into the homogeneous equation, x^2e^x- 2xe^2+ 2e^x= (x^2- 2x+2)e^x NOT 0. The same is true for e2x: it is clearly NOT a solution. (I'm assuming that "2xy" was supposed to be 2xy'.) I thought perhaps you had confused this with a "constant coefficients" equation but ex and e2x do not satisfy y"- 2y'+ 2y= 0 either, the satisfy y"- 3y'+2y=0. This is an "Euler type" or "equi-potential" equation. You can convert it into a constant coefficients equation, in t, by making the change of variable t= ln(x). Hmm. It converts to y"- 3y'+ 2y= 0 which DOES have et and e2t as solutions! It looks like eln(x)= x and e2ln(x)= x2 are solutions to your homogeneous equation.
Redo the Wronskian, using y1= x and y2= x2.
Ah, of course, Euler-Cauchy. Thanks, now I got the right answer.
  • · Replies 18 ·
