Non-homogenous ODE, non-homogenous boundaries
  • Level: Graduate
  • Thread starter Thread starter nrhoades
    Ode
10 replies · 3K views · last reply
nrhoades
I've made a lot of simplifications to a Joule-heating problem I'm working on. I'm struggling to solve the following one-dimensional, one variable ODE:
Txx + aT = -b
with boundary conditions
T(x=0) = Ts (Dirichlet)
Tx(x=L) = 0 (Neumann)
I've learned that this is a non-homogeneous ODE with non-homogenous boundaries. I've tried using FDM to solve them and then fitting the data to a function, but I didn't get far.
I would love some help on this. I have much more experience with numerical analysis than analytical. I really need a math-wiz's help.
I apologize for being to lazy to work out where this really comes from, but here's the solution Mathematica gives:
[tex] T(x)\to \frac{1}{a}\left(-b \cot \left(\sqrt{a} L\right) \sin \left(\sqrt{a} x\right)+b \csc \left(\sqrt{a} L\right) \sin \left(\sqrt{a} x\right)+b \cos \left(\sqrt{a} x\right)-a T_s \cot \left(\sqrt{a} L\right) \sin \left(\sqrt{a} x\right)+a T_s \cos \left(\sqrt{a} x\right)-b\right)[/tex]
pmsrw3, very close! Please see the following two plots:
The equation you gave models the homogenous boundary problem exactly, which is:
Txx + aT = -b, T(x=0) = Ts, T(x=L) = 0 (first plot)
What I need is the solution to the NON-homogenous boundary problem:
Txx + aT = -b, T(x=0) = Ts, Tx(x=L) = 0 (second plot)
the difference being that the x=L boundary is Neumann, not Dirichlet.
Can you do what you did again with this Newmann boundary?
Almost there!
Oops, sorry. I must have left out a '.
[tex] T(x)\to \frac{(a T_s+b) \sec \left(\sqrt{a} L\right) \cos \left(\sqrt{a} (L-x)\right)-b}{a}[/tex]
I simultaneously found the solution. The form is
T(x) = C1*cos(sqrt(a)*x) + C2*sin(sqrt(a)*x) - b/a
where C1 = Ts + b/a, C2 = C1*tan(sqrt(a)*L)
Your solution looks like it takes this form after some trig flexing.
Thanks!
The same result will work. [itex]\sqrt{a}[/itex] is imaginary, but it all works out real in the end. [itex]\cos(i\alpha) = \cosh(\alpha), \sec(i\alpha) = \text{sech}(\alpha)[/itex].
If you want it written in terms of explicitly real functions: Letting alpha = -a, assuming alpha > 0, and solving [itex]T''(x)-\alpha T(x)=-b[/itex], I get
[tex] T(x)\to \frac{e^{\sqrt{\alpha } (-x)} \left(\alpha T_s \left(e^{2 \sqrt{\alpha } L}+e^{2 \sqrt{\alpha } x}\right)-b \left(e^{\sqrt{\alpha } x}-1\right) \left(e^{\sqrt{\alpha } x}-e^{2 \sqrt{\alpha } L}\right)\right)}{\alpha \left(e^{2 \sqrt{\alpha } L}+1\right)}[/tex]
pmsrw3: Last one...
Quickly, can you do:
y'' = 0
y'(x=0) = inf
y(x=L) = a
I don't know if this is possible.
Thanks!
I don't need to run that one -- it obviously doesn't have a solution. y'' = 0 says y' is the same everywhere. y' is infinite at 0, so it's infinite everywhere. Obviously this does not have a finite solution.
I FDM'ed this too and I agree. For some reason it wasn't obvious to me at first. Thanks.
