Proving Non-linear Wave Equation for Riemann Tensor
The discussion focuses on proving a non-linear wave equation for the Riemann tensor in empty space, as posed in Hughston and Tod's text. The initial approach involves using the Bianchi identity, leading to a form that includes derivatives of the Riemann tensor. Participants suggest that utilizing the vanishing Ricci tensor is crucial for simplification. They recommend manipulating the right-hand side to involve commutators of covariant derivatives, which relate back to the Riemann tensor. Overall, the conversation emphasizes the need for a strategic approach to derive the desired equation effectively.
dman12
Hello,
I am working through Hughston and Tod "An introduction to General Relativity" and have gotten stuck on their exercise [7.7] which asks to prove the following non- linear wave equation for the Riemann tensor in an empty space:
eeRabcd = 2Raedf Rbecf − 2Raecf Rbedf − Rabef Rcdef
I have started from the Bianchi identity:
Rabcd;e + Rabec;d + Rabde;c = 0
To give:
ee Rabcd = -∇ed Rabec - ∇ec Rabde
But I don't know what to do to get the RHS into the correct form. Do I use the fact that we are considering empty space such that the Ricci tensor vanishes, Rab = 0 ?
Any help on how to prove this relation would be very much appreciated!
Interesting. If you're told to prove it in empty space, then clearly you're going to need the fact that the Ricci tensor vanishes.
It seems sensible to imagine that you might need the Bianchi identity at some point, since you're differentiating the Riemann tensor, but this looks to me more like something you'd do for simplification at the very end.
None of the possible ingredients you've suggested so far will result in a curvature polynomial of the form R...R...
The only method of attack that I can think of would be to write out the Riemann tensor in terms of the Christoffel symbols. I'm sure this would work, but I imagine it would be really, really ugly.
You could go to Riemann normal coordinates, which might simplify things somewhat.
I am with bcrowell on this one, you do not have enough information to efficiently create your proof. Look back and see what you can find that may help, otherwise we can not help you much more than that.
To give:
This is the right place to start. Now manipulate the RHS of that to give expressions with commutators of covariant derivatives, ##[\nabla_a, \nabla_b]##. Finally, use the fact that the commutator of covariant derivatives gives you a Riemann tensor:
$$[\nabla_a, \nabla_b] V^c = R^c{}_{dab} V^d,$$
etc.
Likes bcrowell
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 28 ·
