awertag
- 63
A NON-monatomic gas expands from I to F in the Figure (Since it is not monatomic U=3/2nRT does not give you the internal energy, this only works for monatomic gases, instead you must use the first law). The energy added to the gas by heat is 424 J when the gas goes from I to F along the diagonal path.
(a) What is the change in internal energy of the gas?
Your answer is incorrect.
(b) How much energy must be added to the gas by heat for the indirect path IAF to give the same change in internal energy?
well i tried using ∆U=Q+W(on) and doing all the possible combinations of positive and negative (finding work from area under curve) but I couldn't get the correct answer for ∆U. I hope you can help!
thanks so much
--aweg
