Non singular matrix M such that MAM^T=F
  • Thread starter Thread starter CAF123
    Matrix
The discussion centers on demonstrating the existence of a non-singular matrix M such that MAM^T = F for any antisymmetric matrix A. The normal form F consists of 2x2 blocks on its principal diagonal, which are either zero or the matrix $$\begin{pmatrix} 0 &1 \\ -1&0 \end{pmatrix}$$. The Gram-Schmidt method is referenced as a means to construct M using an antisymmetric inner product defined by $$\langle x,y \rangle = x^TAy$$. The spectral theorem is also highlighted, indicating that A^2 is symmetric and can be diagonalized in an orthonormal basis.
  • Understanding of antisymmetric matrices and their properties
  • Familiarity with the Gram-Schmidt orthogonalization process
  • Knowledge of the spectral theorem and diagonalization of matrices
  • Basic linear algebra concepts, including matrix multiplication and inner products
  • Study the Gram-Schmidt process for antisymmetric matrices
  • Learn about the spectral theorem and its implications for matrix diagonalization
  • Research the properties of antisymmetric inner products and their applications
  • Explore the construction of transition matrices in linear algebra
Mathematicians, students studying linear algebra, and researchers working with antisymmetric matrices and their applications in various fields such as physics and engineering.
CAF123
Show that there is a non-singular matrix M such that ##MAM^T = F## for any antisymmetric matrix A where the normal form F is a matrix with 2x2 blocks on its principal diagonal which are either zero or $$\begin{pmatrix} 0 &1 \\ -1&0 \end{pmatrix}$$
To do so, consider the analogue of the Gram-Schmidt method for antisymmetric matrices using the antisymmetric inner product ##\langle x,y \rangle = x^TA y##
Gram Schmidt equations?
Orthogonality
I am just really looking for some hints to start. For vectors ##x## and ##y##, $$x^T A y = (x_1 \dots x_n) \begin{pmatrix} A_{11} & A_{12} &..&A_{1n} \\ ..&.. \\ ..& ..&..&A_{nn} \end{pmatrix} \begin{pmatrix} y_1 \\ y_2\\ ..\\y_n \end{pmatrix}$$ and ##A_{ii} = 0, A_{ij} = -A_{ji} ## but I am not seeing how the hint is useful.
Thanks!
I feel that it is a way or another related to the spectral theorem. Try to work on ##A^2##.
In the 2x2 case, ##A^2## is proportional to the identity but this is not true for the 3x3 case and beyond so I am not sure what can be said about ##A^2## in general.
The product ##x^T A x## is the matrix multiplication of a row of ##M^T## together with ##A## and corresponding transposed row (or column) vector in ##M##. The matrix ##M## is composed of the ##2n## vectors ##x## and amounts to the transition matrix from one basis to another. Is that correct? I guess Gram Schmidt comes into play when we want to work with some arbitrary basis and ##M## is the basis change of matrix that takes us to the basis in which we now have an orthogonal set of basis vectors. I just don't see a way to proceed as of yet.
Thanks!
Let's say that ##A## is a real matrix.
If ##A## is anti-symmetric (## A^T = -A##), then ##A^2## is symmetric. The spectral theorem says it is diagonalizable in an orthonormal basis.
Could the diagonal matrix be a representation of ##F^2## in another orthonormal basis ? I don't know, it is just a suggestion, this is how I would start.
If yes, you will get an equality that looks like ##(M A M^T)^2 = F^2##, with ##M## being a product of 2 orthogonal matrices, therefore invertible. But still, there are these squares you'll have to get rid of.
Ok, so given that ##A^2## is always symmetric it can always be diagonalised in a basis spanned by its (normalised) eigenvectors. So, something like $$RA^2R^T = \text{diag}(\lambda_1, \dots \lambda_{2n})$$ Then multiply by ##P## on the left and by ##P^T## on the right so that $$PR A^2 R^T P^T = P\text{diag}(\lambda_1, \dots \lambda_{2n}) P^T \overset{!}{=} F^2.$$ If ##M = PR## then get ##(MAM^T)^2 = F^2##
So somehow I need to prove that it is possible to go from a diagonal form ##D = \text{diag}(\lambda_1 \dots \lambda_{2n})## to ##F^2##? ##F^2## is so specific though about the elements on its block diagonal. And to resolve the sign where I square root both sides i thought about considering ##M=\text{Id}## to get the sign right for det but this depends on how much I'm allowed to assume about ##\text{det F}## (I can see that it is only 1 or 0 though)
Does the hint about Gram Schmidt help me at all and in particular using the quantity ##x^T A y##?
I got the following solution from another source:
We suppose that ##A## is written in the canonical basis. Consider the product defined by ##\langle x,y\rangle=x^TAy##, the bilinear antisymmetric product. There exists a basis ##e_1,...e_{2n}## such that this product in this basis is ##e_{n+1}\wedge e_{1}+...+e_{2n}\wedge e_{n}##. The matrix of the bilinear for in this basis is ##\pmatrix{0 & 1 \cr -1 & 0}##.
Let ##M## be the transtion matrix from the basis to ##e_1,...,e_{2n}## to the canonical basis ##M^TAM =\pmatrix{ 0 &1\cr -1 & 0}##
I didn't completely understand this proof - What does the term ##e_{n+1}\wedge e_{1}+...+e_{2n}\wedge e_{n}## evaluate to and why is the bilinear in this basis in which the inner product is equal to that given by $$\begin{pmatrix} 0 & 1 \\ -1&0 \end{pmatrix}?$$
  • · Replies 39 ·
