How Does Non-Uniform Circular Motion Align with Complex Plane Calculations?
This discussion focuses on the relationship between non-uniform circular motion and complex plane calculations, specifically how derivatives of position vectors in polar coordinates yield radial and tangential components of velocity and acceleration. The participants explore the implications of these calculations on traditional physics equations, such as centripetal force. They emphasize the importance of understanding the differentiation of complex numbers, particularly the role of the unit vectors e^(iθ) and ie^(iθ) in representing these components accurately.
  • Understanding of polar coordinates and their derivatives
  • Familiarity with complex numbers and the complex plane
  • Knowledge of basic physics concepts such as centripetal force and acceleration
  • Proficiency in calculus, particularly differentiation techniques
  • Study the differentiation of complex numbers in polar coordinates
  • Learn about the TNB (tangent-normal-binormal) frame of reference for motion analysis
  • Explore Kepler's laws of planetary motion for applications in elliptical orbits
  • Investigate the Frenet–Serret formulas for a deeper understanding of curves in space
Students and professionals in physics, mathematics, and engineering who are interested in the mathematical modeling of motion, particularly those working with circular and elliptical trajectories.
  • #31
davidbenari said:
I know that it is similar to a vector. A complex number is "just a number" except that isn't necessarily a real number. I see the similarity with a vector, but my question still holds. I argue that it just can't be the same as a vector no matter how similar..
Your argument is invalid. A complex number is a vector, not just similar to one.That is why we need a plane to visualize them. That is why we can use complex numbers to derive statements on 2D vectors, like it was done in your first message. If you really want to argue further, look up the definitions of a complex number and a vector, and show that a complex number does not satisfy the definition of a vector.
  • #32
Those two statements contradict each other.
I would rather put it that a complex number is two dimensional - which can be represented as a vector and this is common usage. But nothing 'spacial' is implied by complex numbers.
  • #33
The second one is not a statement - not my statement at least. So no contradiction as far as I can tell.
A complex number is a vector because all of the axioms of a vector space are satisfied by the set of complex numbers. It is also a vector in the sense that one can be used to represent little arrows on a flat sheet of paper and vice versa, which may be what you meant by "spatial".
  • #34
I get it now. The two statements a actully disagree but you are saying that (and I missed the subtle construction and the earlier few words) that you (one) won't be able to justify the second.
I agree.
  • #35
Well to begin with, arithmetical operations are defined differently for them (except to my knowledge, addition). I agree with sophiecentaur in that they are only representations and there's nothing spatial about them. https://www.physicsforums.com/showthread.php?t=458201 post#4 here says this:
"" Of course you can represent the real and imaginary parts of a complex number as a point on a plane (the Argand diagram) and you can do the same for the components of a 2-dimensional vector. Therefore complex numbers and 2-dimensional vectors will have some "geometrical" properties that are similar. But as you go further into using complex numbers in calculus (for example "analytic functions"), and study things like infinite-dimensional vector spaces where the elements of the vectors are not even numbers at all, you will find there are many more differences than similarities. ""
Apart from that I thought of another argument for my REAL question : If complex numbers add like vectors, then it makes sense that those two terms are their actual components in that direction.
  • #36
Sure, the real and imaginary parts add separately, like orthogonal components of vectors in R2:
Y + Z = Re(Y) + Re(Z) + i(Im(Y) + Im(Z)),
and so on, which allows you to use complex numbers interchangeably with 2-vectors for adding, rotating, etc. As you've already pointed out, however, some of the operations are not the same.
  • #37
We soon get philosophical here. The reason the Maths, in all its forms, 'works' in our physical world is really quite hard to take in. Even just at the level of two beans plus two beans gives four beans. . . .
We look at vectors (2 and 3D) in spatial terms but, once you get more than 3D, you are back to abstractions. No 'direction' at all, even if there is a magnitude.
  • #38
Well yeah, but my question was not philosophical. I think what I wrote on my diagram with the square shows why the complex plane analysis actually does represent the tangential and radial components. I thought (and still do) there was a more general way of proceeding than my diagram analysis.
  • #39
Vector maths works in many dimensions and in many contexts. The Complex plane is just one example of where it works, I think. You seem to be drawing the conclusion that, because the same Maths applies to your two examples then they are somehow tied together in some significant way. I don't see any necessary connection.
To return to my beans, if you follow your approach, you could say that, because two apples plus two apples gives four apples, there is some inherent connection between beans and apples.
  • · Replies 37 ·
  • · Replies 16 ·
  • · Replies 43 ·
11K
