Understanding Local and Nonlocal Operators in Quantum Field Theory
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Operator Qft
This discussion focuses on the definitions and distinctions between local and nonlocal operators in Quantum Field Theory (QFT). A local operator, denoted as ##\mathcal{O}(\vec{x})##, satisfies the transformation property ##\mathcal{O}(\vec{x})=e^{-i\vec{P}\cdot \vec{x}}\mathcal{O}e^{i\vec{P}\cdot \vec{x}}##, where ##\langle \Omega,\mathcal{O}\Omega\rangle=0## with ##\Omega## being the vacuum vector. Nonlocal operators, such as the product ##O(x)O(y)## or integrals involving local operators, do not adhere to the same transformation properties and cannot be expressed as a single space-time argument. The axioms governing local operators are referenced, particularly those outlined by Osterwalder and Schrader.
  • Understanding of Quantum Field Theory (QFT) principles
  • Familiarity with operator-valued distributions
  • Knowledge of the Poincaré group and its representations
  • Basic concepts of functional analysis, particularly in Hilbert spaces
  • Study the axioms for Euclidean Green’s functions as described by K. Osterwalder and R. Schrader
  • Explore the Epstein-Glaser approach to causal perturbation theory in QFT
  • Learn about operator-valued distributions and their applications in quantum mechanics
  • Investigate the implications of nonlocal operators in quantum field theories
Researchers, physicists, and students in theoretical physics, particularly those specializing in Quantum Field Theory and operator algebra.
  • #31
martinbn said:
What is the example of a nonlocal operator?
You give me an example of a local operator and then I will give you an example of a nonlocal one.
  • #32
There is an example in the first post!
  • #33
I'm a bit confused by this discussion. It's obvious that ##O(x) O(y)## is a formally valid operator product, but it's obviously non-local, because it doesn't depend on only one space-time argument.
Indeed, if ##O## is a local operator, by definition
$$O(x)=T(x) O(0) T^{\dagger}(x), \quad O(y)=T(y) O(0) T^{\dagger}(y)$$
with the translation operator (using the west-coast convention and the Heisenberg picture of time evolution)
$$T(x)=\exp(\mathrm{i} x \cdot P)$$
and thus
$$O(x) O(y) = T(x) O(0) T^{\dagger}(x+y) O(0) T(y),$$
which obviously cannot be written in terms of some translation operation with a single space-time argument.
Of course any power of ##O## at the SAME space-time argument is local, because, e.g.,
$$O^2(x)=[T(x) O(0) T^{\dagger}(x)]^2=T(x) O^2(0) T^{\dagger}(x).$$
  • #34
Most likely I am missing something because I haven't seen the definitions. What is an operator in this context?
  • #35
Then the second post with ##y=7## is the example of nonlocal operator.
  • #36
A map from a vector space ##V## to ##V##. See #12.
  • #37
A local operator in QFT is an operator which is a function of the space-time variables, being either a building block (like a fermionic field operator) of or directly being a representative of a local observable (like energy density, charge density,...) fulfilling the properties given in the OP #1.
Thereby the existence of an operator ##P## (the "total four-momentum") is (formally) guaranteed by the fact that the field operators and composite operators derived from them, describing local observables, are constructed such as to build a unitary local representation of the proper orthochronous Poincare group.
I always write "formally", because it's of course being far from trivial to make sense of the operator products, because indeed the operators are more like "distributions" (in the sense of "generalized functions") than usual "functions", and such distribution-valued operators cannot be so naively multiplied as we physicists just do. That's why even in the perturbative evaluation of these products we run into trouble immediately, which then is cured by the renormalization procedures. The most rigorous treatment of the perturbative QFT paradigm I know of is the Epstein-Glaser approach, aka "causal perturbation theory", nicely treated in, e.g.,
G. Scharf, Finite Quantum Electrodynamics, Springer (1995)
  • #38
Well the article says
A quantum field, or local quantum field operator, is an operator-valued generalized function on space-time obeying certain axioms
So, with the notations above ##O(x)## takes as in input a test function and spits out an operator. The variable ##x## in the notation is misleading as ##O(x)## is not a function but a distribution.
  • #39
What is confusing? Also usual distributions are written in this form, e.g., the Dirac distribution ##\delta^{(4)}(x)##. Perhaps I shouldn't have been lazy in omitting the "hats" for operators to make clear that ##x \in \mathbb{R}^4## but ##\hat{O}(x)## are operator(-valued distributions).
  • #40
The notation is not confusing, i am struggling to understand what is meant. For example for the Dirac delta what does this ##\delta (x)\delta (y)## mean?
  • #41
Demystifier said:
Let ##|v\rangle## be a vector in a vector space (not necessarily Hilbert space) ##V##. If ##O(y)## is an operator, then ##|v'\rangle=O(y)|v\rangle## is in ##V##. Hence ##|v''\rangle=O(x)|v'\rangle=O(x)O(y)|v\rangle## is also in ##V##. As far I can see, this shows that ##O(x)O(y)## is an operator.
In the specific example you give in this thread, though, ##V## is a Hilbert space (since we're talking about QM) and ##O(x)## and ##O(y)## are supposed to be operators on this Hilbert space. What Hilbert space?
  • #42
Many quantum states are in fact not in a Hilbert space. Examples are eigenstates of momentum operator and position operator. To avoid these mathematical subtleties and stay on a safe terrain, I talked simply of a vector space.
  • #43
Ok, substitute a rigged Hilbert space or whatever kind of vector space is appropriate for the particular case we are discussing. My question still stands: what space is it?
  • #44
Whatever space is needed to have closeness under the action of ##O(x)##. Do you think that those subtleties would really help to understand the notion of nonlocal operator?
  • #45
And how do we know this is the same space as the one required to have closure under the action of ##O(y)##, since ##x## and ##y## are two different spacetime points?
  • #46
By the requirement of closure under the action of ##O(x)## for all ##x##.
(BTW, thanks for correcting my language: closeness ##\to## closure!)
  • #47
It has the usual meaning, i.e., for any test function
$$\int_{\mathbb{R}} \mathrm{d} x \int_{\mathbb{R}} \mathrm{d} y \delta(x) \delta(y) f(x,y)=f(0,0).$$
  • #48
For free fields it's the usual Fock space. The (rigged) Hilbert space is constructed from the observable algebra as for any QT.
  • #49
Well, no! There is no usual meaning. You cannot multiply distributions. Again you are writing symbols on paper but it's meaningless. The distribution ##\delta(x)## evaluates on test functions. In this case the test functions are ##C^\infty_0(\mathbb R)##, smooth compactly supported functions in ONE variable. The distribution returns the value at the point which it is centred at, for example ##\delta(5)(f)=f(5)##. There is no usual meaning of a product of two distributions, so you have to say what you mean. It cannot be what you wrote. What yo wrote doesn't have the same domain ##C^\infty_0(\mathbb R)##.
  • #50
Going back to my problem. It is still not clear what is meant by ##O(x)O(y)##, given that they are distributions. Even if we ignore that and think of the fields as maps, and not distributions, then it is still not clear to me what that is supposed to be. Even if you ignore the fact that they are operators and consider them scalar functions, what is meant by that product? For instance if the space-time point ##x## is here and now (with respect to me) and the space-time point ##y## tomorrow at noon in Paris, what is the meaning of the product of the two values of the field ##O## at these two events? And if you take all these products over all pairs of events, why is that a field. This is impossible to make sense even in a classical/nonquantum field theory without the mathematical subtleties!
  • #52
Here we have a distribution defined on test functions of two real variables (you can take ##C_0^{\infty}(\mathbb{R}^2)##, ##(x,y) \mapsto f(x,y)##).
Of course, ##[\delta(x)]^2##, meant as a distribution on ##C_0^{\infty}(\mathbb{R})## is an undefined expression, similar to ##1/0## in the algebra of a ring or field.
Such expressions of course occur often in physics, because we physicists are pretty sloppy, and then we have to think a bit deeper. A prominent example is to use plane-wave asymptotic initial and final states with S-matrix Elements ##S_{fi} \propto \delta^{(4)}(P_i-P_f)## and then calculation probabilities by taking ##|S_{fi}|^2##, which of course is an ill-defined meaningless expression. Then we "regularize" the expression and take a more careful limit to make sense of the ill-defined expressions. In this case it's simple, because one should know from classical electrodynamics and quantum mechanics that plane waves are not physically realizable descriptions of fields or states but indeed "distributions" living on the dual of the nuclear space of rigged Hilbert space. So the physical solution is obvious: You have to use true asymptotic free states, aka wave packets, and then also the scattering process being described makes sense.
Another example are infrared and collinear divergences when zero-mass fields ("particles") are involved. There the plane waves aren't even the correct "distribution-valued" (generalized) asymptotic free states, but rather "infraparticles" are. This is cured by either working with the correct asymptotic free "infraparticle" asymptotic free states (e.g., as Kulisch and Faddeev, or Kibble [*] worked out) or you do the more common approach of resumming "soft-photon ladders" (e.g., as detailed in Weinberg, QT of fields, vol. 1).
Last but not least the UV divergences in perturbative evaluation of S-matrix elements are dealed with in renormalization theory.
All this can also be formalized to avoid the mathematical night mares from the very beginning (see the above quoted book by Scharf).
Whether or not a complete mathmatically rigorous non-perturbative existence proof for any realistic QFT is possible, is not known yet.
  • #53
It's used to compute the correlation functions, which in turn are used to compute many physical quantities such as the S-matrix.
It's not a field, it's a product of fields. (You do realize that here the word "field" has nothing to do with fields in abstract algebra, do you?) There is absolutely no mathematical problem with this product in classical field theory.
  • #54
P. Kulish and L. Faddeev, Asymptotic conditions and infrared
divergences in quantum electrodynamics, Theor. Math. Phys.
4, 745 (1970), https://doi.org/10.1007/BF01066485.
T. W. B. Kibble, Coherent Soft-Photon States and Infrared
Divergences. I. Classical Currents, Jour. Math. Phys. 9, 315
(1968), https://doi.org/10.1063/1.1664582.
Divergences. II. Mass-Shell Singularities of Green’s Functions,
Phys. Rev. 173, 1527 (1968),
https://doi.org/10.1103/PhysRev.173.1527.
Divergences. III. Asymptotic States and Reduction Formulas,
Phys. Rev. 174, 1882 (1968),
https://doi.org/10.1103/PhysRev.174.1882.
Divergences. IV. The Scattering Operator, Phys. Rev. 175,
1624 (1968), https://doi.org/10.1103/PhysRev.175.1624.
  • #55
Of course, but that's my point. The question in this thread was to give an example of a non-local FIELD. Now you say that your example is NOT A FIELD!
Same as above. Of course you can do that. How is that relevant to the question. You may as well have given an example of some completely different mathematical object.
  • #56
Fair enough! But as I said several times, it can still be viewed as a field if ##y## is treated as a constant. Just like ##f(x)f(y)## can be viewed as a function of one variable if ##y## is treated as a constant.
  • #57
But if you multiply something by a constant, then it is not much different than the original. How is ##5O## nonlocal if ##O## was local, whatever local means in this context? Is this related to the fact that here we don't have numbers but operators and they don't commute, and we are not multiplying by a constant number but a constant operator? How? Is it ok to multiply like that?
  • #58
Of course. I thought it was obvious all along. Let ##O(x)=e^{-ipx}O(0)e^{ipx}## where ##p## is the translation operator. By definition, this equality means that ##O(x)## is a local operator. Now consider the operator
$$A(x)=O(x)O(7)$$
It follows that
$$A(x) \neq e^{-ipx} A(0) e^{ipx}$$
Hence, by definition, ##A(x)## is not a local operator.
  • #59
You asked for the definition, and I gave it. I don't know, what's so difficult to accept that a non-local operator depends not only on one space-time argument. There's nothing to understand, because it's a definition.
  • #60
##O(7)## doesn't make sense to begin with. ##x## and ##y## are four-vector arguments.
  • · Replies 46 ·
11K
