Norm Verification for Vectors in R^2
74 replies · 11K views · last reply
bugatti79 said:
I have spent 3.5 hours on this trivial problem.
I haven't counted the hours I've spent trying to help you, but I would guess that it's at least that many, just for this thread.
bugatti79 said:
x=(x1,x2), y=(y1,y2) both in R^2
line 1 ||x+y||_#=||(x1+y1),(x2+y2)||_# then using definition of the norm || ||_# we have
= |x1+y1|+2|x2+y2|
Finally! This is what I've been trying to get you to do the whole time. Note that there's nothing fancy going on here. It's just the definition of +, followed by the definition of ##\|\ \|_{\#}##.
However, the notation ##||(x1+y1),(x2+y2)||_{\#}## is a bit messed up. It should say ##\|(x_1+y_1,x_2+y_2)\|_{\#}##.
bugatti79 said:
At what stage do I play with the inequalities?
When you go from line 2 to line 3. Micromass gave you the details.
micromass said:
Line 2 to 3 is wrong. You won't have an inequality. But perhaps you can use
[tex]|a+b|\leq |a|+|b|[/tex]
for [itex]a,b\in \mathbb{R}[/itex].
bugatti79 said:
From ||x + y||# = ||<2, 7>||# because we have x+y=(x1+y1, x2+y2)
From ||<2, 7>||# = |2| + 2|7| because we have the definition of the norm ||x ||_# as |x1 |+ 2 | x2|
Mark44 said:
As already noted by micromass, it's not justifiable.
Your first couple of steps were a good start, though, giving justifications for those steps. If you think about things from this perspective (giving a justification - definition, theorem, etc. - for each step) you will have made an important step toward thinking mathematically.
Given ##x=(x1,x2), y=(y1,y2)## both in R^2
##\|x+y\|_{\#}=\|(x1+y1,x2+y2)\|_{\#}## where ##x+y=(x1+y1, x2+y2)## by definition of vector addition in R^2
then using definition of the norm || ||_# given we have
##\|x+y\|_{\#}= |x1+y1|+2|x2+y2|##
but by the triangle inequality we have |a+b| <= |a| +|b| hence
##\|x+y\|_{\#}\le|x1|+|y1|+2|x2| +2|y2|##
##\le|x1|+2|x2|+|y1|+2|y2|##
## \le \|x\|_{\#}+\|y\|_{\#}## Therefore axiom 4 holds
Mark44 said:
Yes, exactly right. This is precisely what we have been trying to get you to do.
micromass said:
Line 2 to 3 is wrong. You won't have an [STRIKE]inequality[/STRIKE] equality. But perhaps you can use
Ok guys, thanks for your help. I really appreciate it considering you could be spending your time on less trivial tasks. I will tackle part 2 in thread 1 tomorrow. night!
Correct. Here's how I would do it:
For all ##x,y\in\mathbb R^2##, we have
\begin{align}
\|x+y\|_{\#} &=\|(x_1+y_1,x_2+y_2)\|_{\#}=|x_1+y_1|+2|x_2+y_2| \leq|x_1|+|y_1|+2|x_2|+2|y_2|=\|x\|_{\#}+\|y\|_{\#}.
\end{align} As you can see, it's not so hard if you just use the definitions and do one step at a time.
(ii) || ||_3:R^2 defined by ||x||=3|x_1|
Is || ||_3 a special function like || ||_1, || ||_2 and || ||_infty etc?
Or do I proceed as usual to test the axioms?
The last part should be ||x||_3 = 3|x_1|. That line is defining how this norm works
No. The || ||1 and || ||2 norms are special functions. This norm is what is being defined in the top line here.
Decide whether or not the following is a norm defined on R^2, hence verify if it is or prove by counter example if it is not.
Q2 ii
(ii) || ||_3: R^2 to R defined by || x ||_3= 3 |x_1| for x=(x_1,x_2) in R^2
a) Let x be an element in R^2.
Since |x_1| >=0 then by definition we have ||x||_3=3|x_1| >=0 for x_1 in R.
b) ||x||_3=3|x_1|=0 iff x=0
c) Let a be an element in R, then
||ax||_3=3|ax_1|
= |a|(3|x_1|)
=|a| ||x||_3
d) let y=(y_1) be an element in R^2, then
||x+y||_3=||(x_1+y_1)||_3=3|x_1+y_1| we have |a+b|<=|a|+|b| therefore
<=3(|x_1|+|y_1|)
<=3|x_1|+3|y_1|
<=||x||_3+||y||_3
Therefore all 4 axioms hold implies this norm is defined in R^2...?
a) Correct
b) If what you're saying is true, then (0,1)=(0,0). This would imply that 1=0.
c) Correct. I would break up the first step into two, for clarity: ##\|ax\|_3=\|(ax_1,ax_2)\|_3=3|ax_1|=\cdots##.
d) What do you mean by y=(y_1)? An ordered pair isn't equal to its first component. Also, x+y is not equal to x_1+y_1. The latter is a real number, not a vector, so you also can't use it as input for the function ##\|\ \|_3##. Also, the last two inequalities are actually equalities, so replace <= with = there.
Q2 ii
||ax||_3=3|ax_1|
= |a|(3|x_1|)
=|a| ||x||_3
<=3(|x_1|+|y_1|)
<=3|x_1|+3|y_1|
<=||x||_3+||y||_3
Fredrik said:
a) Correct
b) I am actually in 2 conflicting thoughts here and I don't know which is wrong. My first thought is this:
ok, so this axiom does not hold therefore I need to demonstrate by counter example. So if I use this example instead of yours.
since x=(x1,x2). Let x=(1,0) then ||x||_3=||(x1)||_3=3|1|=3. Implies ||x||_3 not = 0 for all x_1 in R
My other thought is this:
Based on what I originally wrote which is this ||x||_3=3|x_1|=0 iff x=0
Wouldn't ||x||_3 =0 always because when I say x=0 I mean x=(x_1,x_2)=0, ie x_1 and x_2 are both 0 in R
d) Ah, because we are dealing in R^2, y should be y=(y_1,y_2).
||x+y||_3=||(x_1+y_1, x_2+y_2)||_3=3|x_1+y_1| we have |a+b|<=|a|+|b| therefore
=3(|x_1|+|y_1|)
=3|x_1|+3|y_1|
=||x||_3+||y||_3
I don't understand why you leave out the <?
I don't know why you write ##\|x\|_3=\|(x_1)\|_3##. x is an ordered pair of real numbers. x1 is a real number. Also, once you have specified that x=(1,0), then there's no need to use the notation x1. If x=(1,0), then clearly ##\|x\|=\|(1,0)\|##. That should be your starting point if you want to try to use (1,0) as a counterexample.
Also, if you have already specified that x=(1,0), which implies that x1=1, you can't say "for all x1 in ℝ".
Clearly x=0 implies ##\|x\|_3=\|(0,0)\|_3=3|0|=0##. What you need to answer after making this observation is if it's also true that ##\|x\|_3=0## implies that ##x=0##.
Yes.
=3(|x_1|+|y_1|)
=3|x_1|+3|y_1|
=||x||_3+||y||_3
You don't. I said "the last two inequalities", not "the last three inequalities". What I'm saying is that it looks weird to write a≤b when you know for sure that a=b. For example, 5≤3+2 is correct, but it still looks weird. So I'm suggesting that you use equality signs when you know that the two numbers are equal.
b) since x=(x1,x2). Let x=(1,0) then ||x||_3=||(1,0)||_3=3|1|=3. Implies ||x||_3 not = 0
Therefore, this axiom does not hold for all x in R^2
Fredrik said:
...if it's also true that ##\|x\|_3=0## implies that ##x=0##.
but that is just the reverse of what you have shown 'when x=0 etc implies...' right?
ok
First off, this is not a counterexample. The axiom is
|| x ||3 = 0 iff x = 0
What you are saying here is that if x = <1, 0>, then || x ||3 = 3. Your vector here is not the zero vector in R2, and its norm (|| ||3 norm) isn't zero either.
A counterexample would be either
a) x = <0, 0> having a norm that is nonzero, OR
b) x is nonzero, but its norm is zero.
Can you think of some other vector in R2 that isn't the zero vector, but its norm is zero?
Second, don't say "since x = (x1, x2). Let x = (1, 0) ..."
Being that this is the 2nd of four axioms, the context here should already be clear that you are dealing with vectors in R2.
Just say, "Let x = <1, 0> ... " (or whatever), and continue from there.
ok
This time, the calculation is correct and the notation is fine, but you have only proved that there's an x such that ##\|x\|_3\neq 0##. As Mark 44 has already said, what you want to prove is that there's an x such that ##\|x\|_3=0## and x≠0. The reason is that "A implies B" is equivalent to "not (A and not B)". The negation of this statement is "A and not B". So if you want to prove that ##\|x\|_3\Rightarrow x=0## is false, you do it by finding an x such that ##\|x\|_3=0## and x≠0.
Yes, but I'll add that the technical term is converse, not "reverse". The converse of an implication ##A\Rightarrow B## is the implication ##B\Rightarrow A##.
|| x ||3 = 0 iff x = 0
I guess fredrik provided a counterexample, ie x equal (0,1). So this is sufficient to show axiom 2 does not hold? I can't think of any other example. So i guess this question is reasonably answered.
Yes, (0,1) is a counterexample to the statement "For all x, ##\|x\|_3=0\Leftrightarrow x=0##, because ##\|x\|_3=0## and x≠0. So ##\|\ \|_3## is not a norm. You got that right.
