Norm Verification for Vectors in R^2
74 replies · 10K views
Fredrik said:
What is the first step that you're not 100% sure about? Do you know the definition of x+y? If yes, then why not use it? Then use the definition of ##\|\ \|_{\#}##. After that you're almost done.
I don't know how to write the definition of x+y apart from what I gave originally..thanks for your patience.
bugatti79 said:
4) ##\forall x,y \in \mathbb R^2## and ##x_1, y_1 \in \mathbb R##
we have ##x+y = x_1+2x_2 +y_1 +2y_2## ...?
So, x and y are elements of R2, meaning that you can write them as
x = <x1, x2>
y = <y1, y2>
Then what is x + y? It is NOT as you wrote above.
I don't recall seeing a definition of x+y in this thread.
Edit: If you meant the equality ##x+y = x_1+2x_2 +y_1 +2y_2## (which is extremely incorrect, since the left-hand side is a member of a different set than the right-hand side), then no, this looks nothing at all like the definition of x+y. It looks like it was inspired by the definition of ##\|\ \|_{\#}##, but I see nothing in it that reminds me of the definition of x+y.
I'm going to bed early tonight, but I'm sure Mark44 or someone else can answer your next post.
Yes, you are correct. Ok, thanks.
It is ##\|x+y\|_\#=...## that I should be focusing on...
Yes, but before you focus on ##\|x+y\|_{\#}##, you should focus on x+y. Do you understand what the notation ##\mathbb R^2## means? What sort of objects are members of ##\mathbb R^2##. How do you add one of those objects to another? Do you at least understand that the notation x+y is completely meaningless until it has been defined? What is the standard definition of x+y for ##x,y\in\mathbb R^2##?
To elaborate on what Fredrik said, how is addition usually defined for vectors in R2? That's basically what he's asking about for the expression x + y. This has nothing to do with norms.
##\|x+y\| \le \|x_1+y_1\|+ \|2x_2 +2y_2\|##
##\le \|x_1+y_1\|+2\|x_2+y_2\|##
If the value of y is 0, isn't it still possible that the inequality holds? ie, the LHS can still be less than the RHS ie
##\|x\| \le \|x_1\|+ \|2x_2 \|##
So I am saying that axiom 4 holds. Is this how one examines it? Thanks
No. What you wrote makes no sense.
We asked you several times, how is x+y defined??
Let [itex]x=(x_1,y_1)[/itex] and [itex]y=(y_1,y_2)[/itex]. Then how did we define
[tex](x_1,x_2)+(y_1,y_2)[/tex]
Try doing just one thing at a time. For all ##x,y\in\mathbb R^2##, we have
$$\|x+y\|_{\#}=...$$ The first step is to use the definition of + to rewrite x+y as an ordered pair of real numbers. The second step is to use the definition of ##\|\ \|_{\#}##. Then there's a third step. Don't try to do them all at once. Do them one at a time.
You also need to think about when to use the notation |something| and when to use the notation ##\|\text{something}\|_{\#}##. Also, in each step, use an equality sign if what you have on the left is the same thing as what you have on the right. Use ≤ only if you have reason to think that the thing on the right may be greater than the thing on the left.
In addition, in this problem ||x + y|| is completely irrelevant. The norm you appear to be working with is ||x + y||#. Use the definition of this norm to first say what this expression equals, and then work on showing that the triangle inequality holds.
##x+y=(x_1+y_1,2x_2+2y_2)##?
NO! Do you not understand how to add two vectors together? You should not be attempting to work problems about norms if you don't understand the basics of vector operations.
No, this is wrong. Note that we're just doing addition here. Those functions that may or may not be norms have nothing to do with it.
Bugatti, I think we could help you better if you would explain us your situation. What course are you taking now? What courses did you already take??
I'm asking this because I feel you miss some preliminary knowledge. We can help you rectify it by suggesting things you should look at.
If v=(v1,v2) and w=(w1,w2) then v+w=(v1+w1,v2+w2)? Thats all I have done above?
I am studying topics in analysis part time so I may be over tired from work. I have done PDE's and Calculus 1,2 last year.
No, it isn't. You were mixing vector addition with the || ||# norm, producing a meaningless mush. Here is what I'm referring to.
bugatti79 said:
x+y=x1 +2x2 +y1 +2y2
So for x,y in R^2 where x=(x1,x2) and y=(y1,y2)
##x+ y= <x_1+ 2y_1, x_2+ 2y_2>##?
No! You wrote it correctly in in your post 45. Why do you keep insisting on the 2?
##x+y=(x_1+y_1, x_2+y_2)##
## \| x+y\|_{\#}= \| |x1|+|y1|, 2|x2|+2|y2| \|_{\#} ##...?
Here you're adding x and y correctly, but why don't you just insert the result you've found for x+y into ##\|x+y\|_{\#}##, and then use the definition of ##\|\ \|_{\#}##? What you wrote doesn't make any sense. The function ##\|\ \|_{\#}## takes a member of ##\mathbb R^2## as input. Here you used a real number as input. That doesn't make sense.
Edit: Why is there a comma in there? Did you mean ##\|(|x_1|+|y_1|,2|x_2|+2|y_2|)\|_{\#}##? That doesn't make much sense either. I mean, it it's not a nonsense expression, but I have no idea why you would consider an ordered pair with those components.
Did you use the definition?
bugatti79 said:
(i) || ||_#: R^2 defined by ||x||_#=|x_1|+2|x_2|
Doesn't look like it to me.
Now I am really confused. I know this is a big ask but is it not possible for one of you to write the answer and then I will query why you did it that way?. I have spent 3.5 hours on this trivial problem.
OK, should it be
##\| x+y\|_{\#}= \| \|x\|+\|y\| \|_{\#}##
That's against forum rules.
Here's an example, though.
Suppose x = <3, 2> and y = <-1, 5>
||x + y||# = ||<2, 7>||# = |2| + 2|7| = 2 + 14 = 16
I can justify every step above. Can you provide a reason for each step?
See if you can use this as a template to calculate a more general result: ||x + y||#, with x = <x1, x2> and y = <y1, y2>
x=(x1,x2), y=(y1,y2) both in R^2
line 1 ||x+y||_#=||(x1+y1),(x2+y2)||_# then using definition of the norm || ||_# we have
= |x1+y1|+2|x2+y2|
=|x1|+|y1|+2|x2| +2|y2|
=|x1|+2|x2|+|y1|+2|y2|
= ||x||_#+||y||_#
I am not sure how to justify going from line 2 to line 3...?
At what stage do I play with the inequalities?
= |x1+y1|+2|x2+y2|
= ||x||_#+||y||_#
Line 2 to 3 is wrong. You won't have an [STRIKE]inequality[/STRIKE] equality. But perhaps you can use
[tex]|a+b|\leq |a|+|b|[/tex]
for [itex]a,b\in \mathbb{R}[/itex].
From ||x + y||# = ||<2, 7>||# because we have x+y=(x1+y1, x2+y2)
From ||<2, 7>||# = |2| + 2|7| because we have the definition of the norm ||x ||_# as |x1 |+ 2 | x2|
= |x1+y1|+2|x2+y2|
= ||x||_#+||y||_#
As already noted by micromass, it's not justifiable.
Your first couple of steps were a good start, though, giving justifications for those steps. If you think about things from this perspective (giving a justification - definition, theorem, etc. - for each step) you will have made an important step toward thinking mathematically.
Yes, exactly right. This is precisely what we have been trying to get you to do.
