Normal modes of square membrane
1 reply · 4K views
bon
Please see question attached
Ok so I've been able to do the first few parts and have derived that Wm,n = c pi / L (m^2 + n^2)
I've thus been able to show that the second lowest freq is a factor of root(5/2) times larger than the first and that there are two modes that have this frequency. But how do you do the next two parts?
How do I show that by combining them it is possible to have a node along either diagonal of the square? I guess I have to add the two solutions and subtract, but then how do I show that these nodes are along the diagonal?
Also what about the last part? How am i meant to deduce the fundamental mode for a triangular membrane?
Thanks!
OK so I've been able to do the first few parts and have derived that Wm,n = c pi / L (m^2 + n^2)
Thanks!
It looks like what you have so far is:
um,n(x,y,t) = Am,n·sin(mπx/L)·sin(nπy/L)·cos(ωm,nt), where ωm,n = (cπ/L)·√(m2 + n2).
You actually had ωm,n = (cπ/L)·(m2 + n2), but since you got the correct ratio, I assume you inadvertently left out the radical. I also took the liberty to include subscripts on u(x,y,t) to indicate what values of m & n are used.
Notice, that if um,n(x,y,t) is a solution to the equation, then, of course, so is un,m(x,y,t).
Not only that, um,n(x,y,t) ± un,m(x,y,t) are also solutions.
In particular, look at u1,2(x,y,t) - u2,1(x,y,t).
Use the double angle identity for sine. Do some factoring, then use the identity:
cos(θ) - cos(φ) = -2·sin((θ+φ)/2)·sin((θ-φ)/2)
That will get the node along the y = x diagonal.
As for the last question: What does it mean for there to be a node along a diagonal?
Edited to add:
It occurs to me that to check for a node along the diagonal y = x, for instance, it may be simpler to simply plug in x for y in um,n(x,y,t) ± un,m(x,y,t), and see if the result is zero.
The other diagonal occurs along the line: y = 1 - x.
