Normalize the eigenfunction of the momentum operator
The discussion centers on normalizing the eigenfunction of the momentum operator in quantum mechanics. The equation $$\frac{h}{2\pi i}\frac{\partial F}{\partial x} = pF$$ leads to the solution $$F = e^{\frac{ipx2\pi }{h}}C_{1}$$, but there is confusion regarding the normalization constant $$C_{1}$$. Participants highlight that the integral $$\int_{-\infty}^{\infty}C_{1}^2\,dx$$ diverges, making the conclusion that $$C_{1} = \frac{1}{(2\pi)^{1/2}}$$ nonsensical. Suggestions include using periodic boundary conditions to properly define the momentum operator and normalize the wave function. The conversation emphasizes the need for careful mathematical treatment in quantum mechanics to avoid misinterpretations.
LCSphysicist
I will post a print
The momentum operator identity
I am just solving the equation $$\frac{h}{2\pi i}\frac{\partial F}{\partial x} = pF$$, finding $$F = e^{\frac{ipx2\pi }{h}}C_{1}$$, and$$ \int_{-\infty }^{\infty }C_{1}^2 = 1$$, which gives me $$C_{1} = \frac{1}{(2\pi)^{1/2} }$$, so i am getting the answer without the h- in the denominator
Pretty sure the error is in the third line. But can't say where there
Doesn't ##\int_{-\infty }^{\infty }C_{1}^2\,dx## diverge?
Yeh but we use dirac notation here just to normalize it (i am still trying to get how this work)
The point is that your third line is non-sensical. It's clear that
$$\int_{-\infty}^\infty C_1^2\,dx \ne 1$$ for any value of ##C_1##, so how you ended up concluding on the following line that ##C_1 = 1/\sqrt{2\pi}## is a mystery.
Do you know the integral representation of the Dirac delta function?
Where is this from? Quantum mechanics is usually presented with some (healthy) mathematical sloppiness in physics textbooks, but obviously you have a book where the sloppiness is used in a way where it becomes unhealthy.
There are many ways out of this. One is to do quantization of a particle in a finite volume (or here in the 1D case finite line). In order to have a proper momentum operator you have to use periodic boundary conditions, i.e., consider a particle at the interval ##(-L,L)## an impose the periodic boundary conditions ##\psi(-L)=\psi(L)## on the wave functions. The momentum operator is given as in infinite space by ##\hat{p}=-\mathrm{i} \hbar \partial_x##.
Now solve the problem first for this space and then take the limit ##L \rightarrow \infty## in the proper way such as in this limit
$$\int_{\mathbb{R}} \mathrm{d} x e_p^*(x) e_{p'}(x)=\delta(p-p').$$
Likes PhDeezNutz
  • · Replies 36 ·
