Normalizing a 4x4 matrix with unknown functions as elements
The discussion revolves around finding the normalization constant for a specific 4x4 matrix with unknown functions as elements. The original paper claims the normalization constant is N=4-2g^2+2f^2, but the user struggles to derive this using two different methods: summing the squares of the matrix elements and calculating the determinant. Confusion arises as the results from both methods do not match the paper's claim, leading to frustration. A suggestion is made to simplify the problem by conjugating the matrix to a lower triangular form, which can help identify the eigenvalues directly. The thread highlights the complexity of matrix normalization when dealing with functions as elements.
fruity_water
Hi All!
This is my first time putting up my own thread on MF. I can usually find what I'm looking for, but this time: no go.
As the title says, I'm trying to find the normalization constant of this 4x4 matrix (g and f are functions):
(1-g^2) 0 0 0
0 (1+f^2) (-g^2-f^2) 0
0 (-g^2-f^2) (1+f^2) 0
0 0 0 (1-g^2)
It's a matrix that's in a research paper which gives the normalization constant as: N=4-2g^2+2f^2.
1]I've been looking up online and found that N can be found with: N=\sqrt{\sum{X^2}} where X represents the elements of the matrix.
2]I also found somewhere which said that I need to find the determinant.
I'm not sure who's right, but I'm not getting what's in the paper.
For method [1] I'm getting as far as: N^2 = 4(1+f^4+f^2g^2+f^2) and got stuck trying to find the square root (it's been a while since I've done multinomial theorem). So I backtracked to see if their N^2 matches my N^2. But their N^2=16+4g^4+4f^4+16g^2-8g^2f^2+16f^2.
and method [2] is giving me something so long, with so many variables of (g^2), (f^2), (g^4), (f^4),(g^2f^4) (and it keeps going for about 3tysomething variables) that I've given up.
So I'm wrong all over the place.
Can someone help me out?
fruity_water confused
I'm not quite sure which normalization you are looking for, there are various normal forms. An easy first step is to conjugate the matrix with the matrix ##\begin{bmatrix}1&0&0&0\\0&1&1&0\\0&0&1&0\\0&0&0&1\end{bmatrix}## and get
\begin{bmatrix}1&0&0&0\\0&1&1&0\\0&0&1&0\\0&0&0&1\end{bmatrix}\begin{bmatrix}1-g^2&0&0&0\\0&1+f^2&-g^2-f^2&0\\0&-g^2-f^2&1+f^2&0\\0&0&0&1-g^2\end{bmatrix}\begin{bmatrix}1&0&0&0\\0&1&-1&0\\0&0&1&0\\0&0&0&1\end{bmatrix}=\begin{bmatrix}1-g^2&0&0&0\\0&1-g^2&0&0\\0&-g^2-f^2&1+g^2+2f^2&0\\0&0&0&1-g^2\\&&&\end{bmatrix}
which is a lower triangular matrix. It allows you to directly see the eigenvalues.
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 26 ·
  • · Replies 52 ·
