Calculating Roll Angle from Sideslip in Aircraft with Dihedral Wings
  • Context: Graduate
  • Thread starter Thread starter SubZer0
This discussion focuses on the challenges of calculating roll angle from sideslip in aircraft with dihedral wings. It emphasizes that while there are semi-generalized rigid body equations in aerodynamics, the complexity of factors such as wing geometry and fuselage shape prevents the formulation of universally applicable equations. The conversation highlights the necessity of using specific aerodynamic properties derived from flight testing and wind tunnel studies to achieve accurate calculations of roll generated by rudder-induced sideslip.
  • Understanding of dihedral wing design in aircraft
  • Familiarity with aerodynamic principles and rolling moments
  • Knowledge of rigid body dynamics in aerodynamics
  • Experience with flight testing and wind tunnel methodologies
  • Research "rigid body equations in aerodynamics" for foundational knowledge
  • Explore "wind tunnel testing techniques" for practical application
  • Investigate "flight test data analysis" to understand real-world implications
  • Study "sideslip angle effects on aircraft dynamics" for advanced insights
Aerospace engineers, aerodynamics researchers, and aviation enthusiasts interested in the dynamics of aircraft with dihedral wings and the effects of sideslip on roll behavior.
SubZer0
Hi all,
Just a generalised question about rolling moments generated by an aircraft with a dihedral wing during sideslip. Are there any equations which relate (generalised) the sideslip angle of an aircraft with a dihedral wing and its rolling moment? I would like to be able to calculate the amount of roll generated as a result of some degree of sideslip induced by rudder action alone.
I would, inevitably, want to use this roll angle to calculate the turning angle and rate of an aircraft. But prior to that, I want to be able to calculate the amount of rudder (and induced sideslip) which will result in a specific bank angle.
Ideas? Inspiration? Any recommendations for books for beginners in this field?
Thanks!
I had high hopes for this forum, but no gurus on here. ;)
The problem is that in aerodynamics, almost nothing can be generalized. To my knowledge, this is not one of the things that can.
There are radio control models that use dihedral and rudder for turning (no ailerons). There is a contest class for gliders that only allows rudder, elevator, and spoilers; try doing a web search for RES radio control to see if you can find any useful info.
As boneh3ad said, very little can be generalized about aerodynamics, and unless I'm forgetting something, he's right that this is not one of the things for which a generic answer exists. It depends on the exact wing geometry, wing position, fuselage shape, and other factors, and as a result, it is usually either done with complicated computer codes or (ideally) with wind tunnel and flight test results.
There is no big problem about general answers to questions like "what is the point of dihedral wings", at the qualitative level of "if you yaw left then this force gets bigger, this one gets smaller, so this happens".
But turning that into equations to predict the dynamics of a particular aircraft design is not generalizable. At best you would end up with a "general" equation containing a bunch of unknown constants, and you would still need to do the detailed modelling to find their numerical values.
And the key word here is "at best". It would likely be an equation so ridiculously complex (if it was one equation) that it would be entirely unuseful.
Hi all,
Thanks for the replies. There are indeed semi-generalised "rigid body" equations relating to aerodynamics, which are specialised through parameters. I wasn't asking the question of whether aircraft aerodynamics can be "predicted" through these equations, just whether they existed, and in this case, the equations relating to sideslip angle, lift, etc, exist, but taking into account specific aerodynamic properties which can be ascertained through (a) flight testing, (b) wind tunnel studies.
  • Poll Poll
  • · Replies 35 ·
