Nuclear Bomb Explosions: Speed & Energy Release
Nuclear explosions occur through a prompt supercritical process, with neutron multiplication happening within microseconds, specifically on the order of 10^-7 seconds. The energy release from nuclear fission and fusion reactions does not happen at the speed of light; rather, it is a rapid sequence initiated by fission-based triggers leading to thermonuclear detonations. The yield of a nuclear explosion is contingent upon the number of fissions that can occur before the fissile mass dissipates. Proper construction of a warhead is crucial to ensure that the reactions occur efficiently and lead to a significant explosion.
  • Understanding of nuclear fission and fusion processes
  • Knowledge of neutron multiplication and prompt supercritical processes
  • Familiarity with thermonuclear weapon design and fission-based triggers
  • Basic principles of nuclear reactor operation and control mechanisms
  • Research the mechanics of neutron multiplication in nuclear reactions
  • Study the design and function of fission-based triggers in thermonuclear weapons
  • Explore the differences between controlled nuclear reactions in reactors and uncontrolled reactions in bombs
  • Learn about the safety measures in nuclear reactors, including the role of control rods
Physicists, nuclear engineers, military strategists, and anyone interested in the principles of nuclear energy and weaponry.
Bison01
hey guys just a simple question, I think.
How fast does the nuclear fusion/fission reactions n explosion occur? Is it at the speed of light?
Will there be any energy release b4 the explosion, Or should only b after the explosion? I always thought the fission/fusion reaction cause it to explode then release energy.
Does the high concentration of energy in Nuclear bombs have something to do with the speed of its explosion? Does it mean the more concentrated the energy the faster it will explode logically?
Thnx in advance.
Nuclear fission does not occur at the speed of light.
Nuclear explosions are an example of a prompt supercritical process that is rather unique. The prompt neutron lifetime is on the order 10-7 s, or 0.1 us.
There is a neutron source to get started, but once started the neutron multiplication occurs very rapidly - on the order of microseconds.
The yield is determined by how many fissions can occur before the fissile mass dissipates.
Thermo nuclear explosions are initiated by fission-based triggers, so there is a fission detonation before the thermonuclear detonation.
Thnx for the response
Its just that I read some site where it says the reactions occur n explode at hundred billionth of a second, I jus wanted to confirm it.
So I am guessing no energy should be released til after the explosion.
thnx for the additional info. good night. Peace.
Each time a reaction happens it releases the same amount of energy. If you don't build it correctly, the warhead will get blown too far apart for any more fission to occur before you can reach a large explosion.
For example, in nuclear reactors they use radioactive materials to generate heat to power a steam turbine. The materials are carefully protected by control rods that absorb neutrons and keep them from initiating too many reactions at once and leading to a runaway reaction. Same effect as a nuclear bomb, but it's a controlled reaction instead.
